Question about JVC Everio GZ-MG130 Camcorder
I want software for copy the files from Camcoder to PC
  • 3 Answers
I want software for copy the files from Camcoder to PC. i hv lost the cd
Posted on Oct 09, 2010
3 Suggested Answers
SOURCE: vfk-1340 pc evr adj software
how can find software problem in camcoder
Posted on Aug 20, 2008
SOURCE: copying finalised minidisk to pc
vdr-d100 when I called Panasonic, he stated that this model cannot be setup on the pc. It also states this in the manual, vdr-d200 will connect with pc and comes with software.
I can plug in usb cable on vdr-d100 and view video on quick play. Some dvd's don't work well with model. I have had problems with doublesided fuji dvd-r. So I only use single sided. Panasonic .com has updates and drivers for this model and has the manual you can download.
With windows xp I used DVDSanta and was able to create a large dvd but have not found a solution for vista.
Posted on Mar 19, 2009
Cannot transfer videos onto my computer. Took pictures/videos in HD
Hi I faced the same issue with VideoCam Suite 1.0, from some blog I found that the camcorder uses PAL but the software used NTSC, which is not compatable with each other, hence reinstalling a PAL version of VideoCam Suite should take care of the issue.
However I am still searching for a VideoCam Suite with PAL support.
Aug 26, 2009 | Cameras
I have filmed on to a tape, and now am trying to download on to my PC and store it there. How please?
hi
most camcoders do have a USB connectivity cable and using this connect the camcoder to the PC
once connected u will need to install the required drivers for the Camcoder to be recognised by the PC (this is a one time process)
then the firmware with the Camcoder will also provide u with some basic recording software u may install that too and then go to the starting of the tape (rewind on camcoder) and play and at that point in time click on the record button on the software installed on the PC
hope this helps
Cheers
Jun 23, 2009 | Video Cameras
Can't upload video from Canon Vixia HG20 camcorder
My knowledge in video editing is limited, but here's what I could dig up.
m2ts is also referred to as AVCHD, (MPEG4) a high-def Interlaced format which most computers cant render properly since most computers render in progressive format. You have to convert it to MPEG2, AVI, WMV, MOV or other movie file types in Progressive mode, a process known as "Deinterlacing" in order to edit it. Depending on how big the file is and how fast your computer is this could take several hours. Also, you cant view AVCHD files on normal televisions, you need a high-def TV.
If you want to edit high-def videos with post-effects and music etc, for dvd or blue-ray, you'll need a more powerful computer. The "recommended" minimum is a 64bit dual core processor, windows vista 64 bit, a seperate 500Gb or bigger hard drive and at minimum, 3-4Gbs of RAM with a high-def TV monitor. (1080i) Rendering High-Def videos is process heavy and can take up to 12+ hours to render a single 30-60 minute video with post-fx like music, logo's etc. The reason you need a 64bit processor and 64bit windows is because regular XP and Vista wont recognize more than 3Gb of RAM.
You could get by with a 32bit dual core processor and 2 gigs of RAM on windows XP, it's just going to be slower. You will still probably need a high def monitor if your going to edit in high-def mode.
High-def is new technology to mainstream consumers. Supporting technology hasnt caught up yet including most software--however most of what I read stated that Sony Vegas Platinum can do this pretty well.
Your camera is capeable of recording in progressive mode. You'll have to read the manual on how to do this. This will record it in standard mode which is not high-def. (For future reference)
To sum it all up, the camera's technology is more advanced than most PCs. I downloaded AVS Video Converter and converted the AVCHD, (MPEG4) a high-def Interlaced format to HD Video 720p: WMV9, 7000 kbps....... on the drop down screen of the AVS program. I now can view my videos in Progressive Standard mode with NO choppy play back or problems. Please note that 720p is a non digital standard Television view.
Hope this helps.
Jan 08, 2009 | Video Cameras
Copying finalised minidisk to pc
try NERO 8 full edition enter all serials..
Oct 29, 2008 | Panasonic VDR-D100 DVD Camcorder
Lines on camcoder lcd
the problem was solved automatically by connecting the camcoder to the pc which had the jvc software installed to it.
Aug 18, 2008 | JVC Everio GZ-MG21 Camcorder
Camcoder problem
The USB port on the camera is to download still pics from the Camera's SD Card to your computer. USB connector is not for video downloading.
For video downloading you have to use FireWire port. Your computer must have a FireWire port too. You will need some sort of video downloading software - like Microsoft's MovieMaker. There are some free software to download videos from mini dv camcorders to computer. It takes 1Hr to download 1Hr tape - you have to play it all to record it all. You will need video editing software to do different editing if you want. Otherwise, MovieMaker can make a good avi file. You can upload that to YouTube.
3yrs ago when I purchased this cam, I did not have FireWire port in my computer. I searched online a lot and found a way to download video using USB - it was tough, complicated. It was possible, but quality was too bad and too many dropped frames.
If you do not have firewire port, google for FireWire PCI Card, should be <$10. You have to install it inside your PC. Also search for FireWire cable ($10+/-) that will match BOTH camera and PC ports.
Thank you.
Aug 18, 2008 | Panasonic PV-GS19 Mini DV Digital...
Vfk-1340 pc evr adj software
Jan 05, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
Camcoder Registration Key
unfortunately you can't upload music and games from your pc on this mobile phone
however you can synchronize your contacts and calendar from Outlook to your phone using VSender software
download it here :
http://www.nokiausa.com/A4425160?url=http://nds1.nokia.com/files/support/nam/phones/software/vSenderInstall.zip
Dec 19, 2007 | RSA Security Keon Registration Authority
Camcoder
you have to format phone memory of your P910 because some file is corruptet.Before you do this make a backup file on your pc to save your stuff.
Jan 13, 2007 | Sony Ericsson P900
JVC Everio GZ-MG130 Camcorder Logo
71 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
