Question about NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair
When I press the Run button, the Battery Level lights flash on and off rapidly (all at once, 2 or 3 times per second) and I get a beep-beep error signal. I had just used the chair a few minutes before and it seemed okay. What is this telling me and how do I clear the problem?
    Novelist:
    Champion:
  • 232 Answers
To diagnose the problem, I need to know how many bars are flashing. If the power chair was jsut working and now it is not, you may have accidentally knocked a manual brake lever out of position with your heel. Take a look at this website to find out what the flashing lights may indicate is wrong with your power chair.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Posted on Oct 11, 2010
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Lights 2 and 7 and constant beeping
Error code 66 is water pressure sensor.
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Dec 06, 2012 | Fisher and Paykel GWL11 Top Load Washer
The Drying light flashes and the unit beeps about once per second. At the same time the unit acts like it is washing (sounds of water washing insiide. The bottom is oompletely full of water.
so its beeping and flashing once per second correct this beeping and flashing is an error code that your unit is giving blinking lights or beeping sounds may indicate a problem with the dishwasher caused by power surges. To correct the problem, try pressing the "Start/Reset" pad to reset the dishwasher. If the problem persists, reset (reboot) the control by turning off the circuit breaker supplying the dishwasher for 30 seconds. Turn the circuit breaker back on and the dishwasher should function normally if you still have the flashing and beeping message me back Im going through the error code book as I type this if it still persists after you turned off the power then back on message me back with the number of beeps within 60 seconds as well as the number of flashing lights for instance if it does it every second or once every 5 seconds also if you have any further questions message me back them as well and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situaitons Thanks Rick
Feb 04, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
I need to reset the oil change light.how do I do This?
1. Engine off, turn ignition key to RUN - do not start engine - make sure dashboard indicator lights come on
2. Put foot top of accelerator
3. Completely depress and release the accelerator TO THE FLOOR, THREE TIMES in rapid succession, within FIVE SECONDS - press release, press release, press release. Then wait a few seconds and the CHANGE OIL light should usually flash, sometimes accompanied by a few short beeps. Once it flashes it should disappear, and it should be reset.
Dec 22, 2010 | 2003 Pontiac Grand Am
I have set the run time on my salt water pump and then locked it back to pushing the buttons it shows the time but there are no green lights showing. Did I forget to do something?
one the run time is set you have 2 options
wiat 2-10 minutes for the system to lock itself and for the second green light to come on this mean you are generating
The other method is to lock it yourself do this by once your hours appear for run time then press and hold down arrow again till beep then press and hold up arrow till beep the hour will stop flashing and in 2-10 minutes your second green light will come on
Jun 12, 2010 | Intex Automatic Salt Water System for ...
Error light flashing
Toner is empty for slow flash 1 per second
Toner is low for quick flash 2 per second
Aug 16, 2008 | Konica Minolta PagePro 1400W Laser Printer
Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Aug 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Program garage door opener
You must first erase what's in the memory.
1.) Simultaneously press both buttons 1 and 3 on the Audi's built-in remote. Hold them until the indicator light flashes (20 seconds or longer).
2.) Now hold your garage door remote close to the Audi remote.
3.) Simultaneously press and hold both your garage door remote button and the button you would like programmed. The indicator light will first flash slowly then rapidly.
4.) You may release both buttons once the light flashes rapidly.
Jul 01, 2008 | 2000 Audi A6
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair Logo
150 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
