Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Moldy smell Could there be standing water inside which is moldy?
    President:
  • 1,294 Answers
A solution/suggestion from the internet:
Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda.
It should clean the machine and move out the bad smell.
Another:
I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution.
MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts.
They are not very cheap but they work great --
I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain.
YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health!
I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com
Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine.
Posted on May 30, 2008
Moldy smell in maytag washer
Check the drain. It SHOULD stand about as high as the washer, behind it, and it SHOULD have a trap below the floor (basement?).
If the drain's good and the trap is fine, then the pump could be borderline - it it doesn't pump all the water out, some water remaining in the washer may become stagnant and smell funky.
Jul 25, 2014 | Washing Machines
Moldy smell
That moldy smell that you get is from all the condensation water sitting in the condensation pan between seasons, if the unit is accessible, you could clean the algae from the pan, also, if the unit is located in a external are, it doesn't hurt to wash the coils with a coil cleaner and water.
Jun 22, 2012 | Dometic Rooftop RV Air Conditioner
An awful smell!!! We have emptied the freg and freezer and it still smells like something is dead...
mix vinegar and water and wash inside walls- place a shallow bowl with more straight vinegar inside an leave for a while.
check underneath in back for a drip pan under the motor- can get moldy- clean with same solution as above
Jun 05, 2011 | Frigidaire Refrigerators
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
MOLDY SMELL INSIDE THE TRUCK, AC WORKS FINE IN THE SUMMER, BUT THERE WAS EXCESSIVE WATER CONDENSATE UNDER THE TRUCK EVEN IN THE FALL, NOW IT SMELLS MOLDY. CAN I CHECK THIS MYSELF? WHERE IS THE CONDENSATE...
look on the outside of firewall for the drain it could be blocked ,but you saw it on the road so i dont think this is your problem,try drilling a 3/8 hole in the lowest point of the floor so if windscreen or something is leaking it can run out again .
Jan 21, 2010 | 2006 GMC Sierra
My Maytag Neptune washing machine makes clothes smell moldy
The problem may be standing water in the discharge hose. If this is the case unplug the machine and remove the hose from the back of the machine, and water will poor out. If you smell mold from the hose, this could be the cause. Rinse the hose out thoroughly with bleach, if its a corrugated hose they are prone to standing water inside and you may want to replace it with a non- corrugated hose. I suggest you run the machine when hose is re- attached with only bleach a couple of times and leave the washer door ajar to completely dry the inside of the drum afterwards, too. I hope this helps you! Good luck!
Dec 29, 2009 | Washing Machines
There is a moldy smell....I have ran a load with no clothes and just bleach and it smelled ok for a week and now smells again
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub/basket, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 24, 2009 | GE WSXH208A Front Load Washer
Moldy smell inside GE profle top loader washer
Check the pump and make sure that it is draining the water. There will always be a little water left over but you should never be able to hear it very easily. Once you check the pump and make sure it is operating properly check the water sensor to make sure that it is acuratly reading the water hieght. After that take one cup of Vinegar and run a hot load of water will kill the mold and clean your system out
Feb 21, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
Moldy smell in washer
run cycle using bleach only in water after cycle use a bleach/water solution to thoroughly wash door seal be sure to pull seal at bottom of drum opening and clean inside lip in future leave door open as much as possible between cycles just remember YOU ARE NOT ALONE..all front loaders no matter the brand have same issue some just worse than others
Jun 18, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
82 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
