Question about GE Washing Machines
I have w56 washing machine, the program has been completed but the front load door can not be opened and the door locked indicator is still on. Please, advise, Thanks,
  • 1028 Answers
SOURCE: My whirlpool LHW0050PQ4 compact front
probably motor control bd but on some early models when both control bds (1 under top and 1 under bottom panel)came together in a kit worked great since sometimes hard to determine exactly which control bd was actually causing the problem if you are sure wash motor is not running and belt is not off
Posted on Jul 05, 2008
SOURCE: GE Adora Front Load Washing Machine Problem
I had a similar problem...with the added issue of the door not locking at all. I cleaned the filter and all is well. However, it took me hours to find the 3 screws everyone was talking about The screws are at the very bottom of the washer, under the lip, facing front. If your machine sits on a pedestal drawer like mine, they are located between the machine and the pedestal. I hope these pics save someone a little time...
Posted on Aug 27, 2008
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
SOURCE: GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Posted on May 07, 2009
  • 4 Answers
SOURCE: unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
Posted on Aug 19, 2009
The machine door wont open after it finish the wash cycle
There should be a LOCK ICON with an LED to tell you whether the Front Load door is locked or unlocked.
If the machine door wont open after the wash cycle, the dryer function or the drainage function hasnt completed.
What you can try is just choose the dryer function after the completed wash cycle if the problem arises again.
IF that doesnt work, then look at bottom of the machine; there should be a flap present which you generally open up to get to the manual drainage valve.. you just pull that open and drain any leftover water .. After the water recedes.. the LOCK icon should be off and you can then open the front load door
Dec 07, 2014 | Indesit W 123 Front Load Washer
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    I have a front louder newer model samsung washing machine. The door was forced opened during cycle and now the lock is still in the locked position and I cannot reclose the door or get the locked to unlock...
    The machine has to reset to bringg tthe lock to release, check the link to the lock settings to make the program complete the cycle and release the lock. Do not force it as you end up damaging.
    Sep 01, 2010 | Samsung WF206ANS Front Load Washer
    Door wont open on bosch classixx 6 1400 express washing machine
    The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
    Thank you !
    May 19, 2010 | Bosch Classixx WFL 2066 Front Load Washer
    I am getting a dl w/an f error
    "dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
    -> Door lid is not closed completely due to interference.
    -> Wash media buildup is preventing the lock bolt from extending.
    -> Machine/motor control detects open door lid switch when attempting to lock.
    -> Machine/motor control cannot determine if door lock is in a locked state.
    Check for lock interference with lid or lock bezel
    Jan 19, 2009 | Kenmore Elite 45986 Front Load Washer
    F22
    I have search for this and found:
    This error code indicates that the door is not locking.
    Is the washer door firmly shut?
    The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
    Were you washing a large load?
    Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
    More info can be found on The Whirlpool website:
    Whirlpool Front-Loading Washer
    Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Fdl code message
    Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    I am getting an DL F code on my front loader
    Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
    Washer flashing dl on the screen
    Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    189 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
