Question about ASUS P4S800-MX Motherboard
Installing XP on a PCI SATA Card
Hi
I am trying to install XP Pro SP2 on a PC with 3.0 GHz CPU and P4s800-MX board. Using F6 i detects the card and setup starts and copy the files but after first reboot the Mother Board doesn't detects SATA HD connected to PCI card and Disk Boot Failure message appaers.... Any Suggestion
  • 101 Answers
Hey change ur boot order in bios.....
put dvd/cd drive 1st...
Posted on May 30, 2008
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
I have IBM Intellistation Z Pro 6221. I tried to install XP, I press F6 for SCSI driver. Then It prompts Press 'Enter' for install or 'R' for repair. Whatever I press it displays No hard disc detected
You need a floppydisk including the Driver for the SCSI or Sata drive - Depending which HD You are using.
If the controller is in motherboard You will find the driver from motherboard webpages.
If it's a separate controller card - You will find it from it's web pages.
XP doesn't support too well sata if it's not the XP SP3 version media.
You may need to change the sata to compatibility IDE mode to get it up and running.
Jan 06, 2011 | IBM IntelliStation Z Pro 6221 PC Desktop
Hi I am unable connect a nvidia Geforece graphics
Why did you have to reformat? If you can i would test video card in a good working pc,,
Mar 30, 2010 | ASUS Motherboard P5n-mx
Is it possible to upgrade to hd graphic card on ASUS P4S800-MX se?
Yes you can use buy another graphics card and install it on motherboard in PCI Slot which given on board
Regards
Ashly
Feb 02, 2010 | ASUS P4S800-MX Motherboard
Sata HDD NOT DETECTING IN XP SETUP
If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
Sep 11, 2009 | ASUS P5RD1-VM Motherboard
Need graphic card agp slot?
an agp slot card is the older type the newer one is pci express.
if you are buying a graphics card make sure you dont buy the newer pci express if you board only supports the agp type
May 06, 2009 | Intel Celeron D 355, 3.33 GHz...
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
PC wont boot, not even to bios
Maybe the mobo is shot for u and he has his PSU shot.......Check for any burnt smells from the mobo. See if the cable from the PSU is properly connected to the mobo. Try removing all drives like graphics cards, RAMS one by one and see if it works.
Aug 18, 2008 | ASUS P4S800-MX Motherboard
Installing NVidia 8500GT XFX 256MB graphics to A8N-VM Motherboard
The chances are that you have an old motherboard which is not compatable with the new graphic card. Or you may be running windows 98 and are downloading the driver for xp or visa versa. The probable solution, will be to sell the new card on ebay and buy the best old card you can off ebay. Or just make do with the card you already had in your computer. If you are determined to have a better graphics card. A motherboard upgrade with better graphic card may be the best answer or buy a better spec pc second hand if you don't have much money. You'll probably waiste a lot of time trying to get the new card to work and it probably never will.
Jan 28, 2008 | ASUS A8N-VM Motherboard
ASUS P4S800-MX Motherboard Logo
165 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
