Question about Garden
Toro 6.5 hp Mower Model 20487 Serial # 200001326 Initially, the mower would start and run for 3 seconds. I removed the carb and cleaned the bowl and jet holes in the bolt that holds bowl. The float appears to work freely. Upon reassembly, the mower runs at a very fast, unsafe speed. I can't reduce the speed, only shut it off. The cable that operates the linkage above the carb appears to work properly. Are there other adjustments?
  • 755 Answers
The linkage on the top of the carb should go to a spring loaded arm that goes into the side of the motor. Work the lever back and forth and see if it works the carb. If it does and everything is in place your governor mechanism inside the engine might be damaged.
If the arm isnt working the carb it is probably bound up or attached to the wrong hole in the carbs throttle lever. There should be two holes and one of them would force the throttle wide open everytime reguardless of what the governor arm tries to do.
Posted on Oct 11, 2010
I have a 6.5 hp toro lawn recycle mover , that will start, but will not continue to run but a few seconds
Their's a bowl under the carburetor ,remove gas from tank or pinch gas line and remove ***** under bowl and gas will come out,clean bowl and reinstall and start it up,Trash gets in their,need a inline filter to stop it.Lowe's has them,3 dollars.
Mar 16, 2016 | Toro Power Lawn Mower
Toro briggs OHV runs too fast
throttle spring could be broken stretched or missing
Nov 14, 2012 | Toro Lawn Mower With Toro Power Tools
When trying to start fuel spits out of the carburator
Remove carb float bowl. Clean bowl. Get model no. of engine and get new float bowl gasket set at mower repair store. Ensure float drops down freely with float bowl removed. Push up on float to stop fuel flow. If not working properly replace float and meter needle.
May 31, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Rough idle on mower
Remove air cleaner and replace filter. Spray carb cleaner in choke at choke flapper. Remove carb float bowl and clean. check float bowl screw for hole thru it, clean out with thin wire if present, reattach bowl and screw, ensure gasket on top of bowl is good, Have mower model no. get new bowl gasket kit at mower repair store.
May 25, 2012 | Toro Garden
Toro Model 20041 sputters and stalls out; If I cover the primer bulb the engine will rev up and run. Also the mower won't start unless I clean the spark plug. What do I need to do?
Most likely you'll have to remove the bowl nut, under the carb's bowl. You'll most likely find varnish in the jet, or maybe water. These are some typical jets, Tecumseh. Briggs, similar (baymee Lehigh Valley PA, 2009).
Jun 08, 2011 | Toro Personal Pace CARB Walk Power Mower
Mower starts fine but conks out in about a minute or two.I changed the air filter but it still stalls a minute after starting. toro mower is about 2 years old
Recheck your fuel selector to make sure it is ON. Also if this is the first start of the season there may be old gas / debris in the bottom of the float bowl. One other area to check is the bottom of the gas tank / fuel outlet port of the tank. I don't remember if this model had an in-line fuel filter but also something to check if installed.
This is listed under Toro Mower with power tools that has a 6.5 Briggs and Stratton engine.
To clean the carb passages you will need to do the following.
(FUEL SELECTOR OFF)
1. The adjustment screw on the side of the carb that has a spring on it. You need to count the number of turns it takes turning it clockwise until it just comes up snug NOT TIGHT. Then remove it.
2, Remove the float bowl and dump the contents.
3. Spray carb cleaner in the adjustment screw hole.
4. Disconnect the fuel hose to the carb and spray carb cleaner in the brass tubing hole. The cleaner should be exiting via the float needle. Make sure float assy is down....
5. Connect the fuel line. (use a spray paint can lid and catch the fuel in this step. FUEL SELECTOR on. Catch fuel exiting carb. Lift the float to a LEVEL position and feul flow should stop. DO NOT FORCE IT! Gentle lift only.
FUEL Selector off.
6. Install float bowl
7. Re-install adjustment screw/needle/spring in the side of the carb. Turn it until it just snugs up.. then back it off the number of turns it took to initially close it before removal.
FUEL Selector on... wait 30 seconds..
7. Start mower.
That should do it.
Kelly
May 03, 2010 | Toro Lawn Mower With Toro Power Tools
My toro lawn mower will start with the primer button but quits after that gas runs out.
Had this problem after I inherited the same mower. Take the carb off and remove the "bowl" using the bolt at the bottom. You will see a plastic float and a needle valve. Remove the float by puling the the pin and clean the needle vale and ensure it moves freely. Also clean the "jet" that holds the float washer to the carb assembly. Also clean the bolt that hold the bowl on.
Mar 30, 2010 | Toro Lawn Mower With Toro Power Tools
Totr model #20479 GTS 5 motor, when you push prime
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Nov 16, 2009 | Toro Lawn Mower With Toro Power Tools
Mower won't keep running after 10-15 seconds.
check the air filter & also spray some carb.clean in the carb see if that helps
Jun 06, 2009 | Toro Lawn Mower With Toro Power Tools
Mower will not stay running
You have a problem in the fuel system. First start by checking fuel lines,filter,vacum fuel pump.If this checks out,remove carb. and clean. Check for water and trash in bowl of carb. or tank. This sould solve your problem.
May 14, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
386 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
