Question about Acer Aspire 5100 Notebook
System Lagging, BSOD, etc.
About two weeks ago, I came home from work and I saw my laptop was off. I knew something was wrong because the AC adaptor light was on, so I knew it was plugged in, and my laptop was on when I left for work. I turned my laptop on, and it came up with a BSOD and stated a 'fatal system error'. I turn off my laptop, boot it up again, and select 'start windows normally' selection from the prompt. Vista begins to load, but my laptop all of a sudden shuts off. I repeat the same steps again, and it goes off, yet again. Finally, I turn it on and it loads, but everything is running at a reduced framerate. A couple of weeks go by, and last week, it happens again, but with no BSOD, and one less shut off. Since then, I can barely run a simple Java-based game on my browser, my typing is severely laggy, and my laptop is getting hot within minutes. I went to Circuit City to ask them about it and all I got was a "Yea, that's a problem you can get". I don't want to go and shell out 60 dollars for them to tell me that, but with them fiddling with my computer. Can anyone give me some insight on what I should do? I'm short on money at the moment, and I need to get this remedied by the time college rolls around this August.
    Genius:
  • 2,785 Answers
Try to boot in safe mode, if the problem persists then try to boot in last good configuration(for both you have to press f 8 when the bios screen comes when pc is booting)
if all fails then reinstall you operating system will solve the problem
Posted on May 30, 2008
My Lenovo s10 power adaptor (Input 1.7A, Output 20V 2A) was working just now together with the battery. After i didn't used the laptop for an hour and returned to switch it on, the power adaptor isn't...
hi,
You said laptop is working fine if just using the battery,that means that there is nothing wrong with the battery itself. Can yu please try to connect the laptop directly to the power outlet without using the battery just for the mean time,remove the battery and connect the AC adapter directly to the power outlet then power on the laptop,if nothing happens,that means that there is something wrong with the AC adapter itself or the power port on the laptop.
Hope this will help...
Jan 09, 2011 | Lenovo IdealPad S10 Laptop AC Power...
Dell laptop wont turn on. battery only works if it is already charged and it doesn't run on A/C power.
It means that is something wrong, most surely with te AC/DC adaptor. Try with other compatible adaptor or take the laptop to service.
Nov 02, 2010 | Dell Latitude D505 Notebook
My crankshaft is very wobbley and make a very high pitched squeak
You need a harmonic balance. Very common problem!
May 21, 2010 | 1995 Geo Prizm
My laptop wont get power and I have tryed a knew
Take out the battery and try running it on the power adaptor alone.
If this works, you have a dead battery.
If not there's something more serious wrong in the machine.
Apr 14, 2010 | Computers & Internet
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Inspiron 1525 ac adaptor not recongized
Do a system restore to a time before the issue.
start>programs>accessories>systemtools>system restore.
Jul 16, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron B130 Battery Problem
Sounds like the cells in the battery went bad. Try to turn on your laptop with just the ac adaptor hooked up and your battery out off the laptop to make sure that your ac adaptor is working properly. If you can boot up into windows with just the ac adaptor hooked up then you know your ac adaptor is good.
If you get that far then try a different battery and see if the laptop charges with another known good battery. If it does then you know your original battery is bad. If it doesn't charge your different known good battery then you know the motherboard is bad. Hope this helps.
Ben
May 26, 2009 | Electronic Arts The Lord of the Rings: The...
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
My IBM do not turn on.. IBM A21M..
check power ac adapter and batery if the batery is ok or charge do a test to the hard drive and memory ram loock on BIOS
Jan 03, 2008 | IBM ThinkPad A21m 2628 Notebook
Help
sounds like you have an intermittent problem with your AC adaptor or dc input jack. Does the light on the AC adaptor light up when you plug it in? If it does then your dc input jack may be faulty. If the light on the ac adaptor does not light then replace the ac adaptor. Good Luck!
Sep 16, 2007 | Toshiba Satellite M30-S350 Notebook
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
