Question about Asko Washing Machines
My asko w6222 shows F3 and stops. What is an F3 - some kind of error?
  • 8,596 Answers
Drainage error
If F3 is flashing on the display, there is a
drainage problem. Check:
• that no objects are stuck in the drainage
hose outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump (see the
"Care and cleaning" chapter).
• that there are no kinks in the drainage
hose.
After taking the necessary action, run the
Drain program or press the Door Opening
button (key symbol) to empty the machine. If
the problem persists, contact the Customer
Care Center at
1-800-898-1879
www.askousa.com
Posted on May 30, 2008
My ASKO W6222 won't drain
Sounds like the inlet water valve is not seated properly and is letting water in when it shouldn't .
Jun 20, 2012 | Asko W6222 Top Load Washer
What does f3 flashing mean?
F3 error code means your washer has not drained. To fix the washing machine error code is simple and straight forward. Simply remove the drain pump filter and slide the filter out and clean the debris inside. The filter in most cases is on the lower bottom panel. Simple depress the tab and fold the access door down. The washer drain pump filter is a white handle twist the handle to remove the filter. You may also find an article of clothing trapped down where the filter is like socks or change etc. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks Rick
Jul 08, 2011 | Asko W6222 Top Load Washer
During the washing circle the machine stops and F3 appears in the time window and machine cant restart
If F3 is flashing, then you are having a problem with drainage.
Check that there is no object stuck in the drain hose outlet. Check that the pump is not blocked by foreign objects and clean the pump. Check that there are no kinks in the drain hose.
After making these corrections, run the drain program or press the key button (door open) to empty the machine.
Feb 10, 2011 | Asko W6222 Top Load Washer
Hi, I have the ASKO W6222 front load washer, my
if the valve was stuck open it would run all the time the washer was on i would say that there is a power short running to the valve turning it on when not selected
sonic boom electronics australia
Jan 04, 2011 | Asko W6222 Top Load Washer
How do you remove the agitators on the asko w6222 front loader(not the "use and care guide" book respose please)
dont be afraid to use pressure and lean the screw driver to the left as you pull down on the agitator goodluck
Apr 08, 2010 | Asko W6222 Top Load Washer
ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
May 24, 2009 | Asko W6441 Front Load Washer
Asko washer model W6222 Error message F3 what does it mean and how to solve
guides.homeeverything.com/cache/FILE24924.PDF
to fix this, check this out - addresses all issues with this machine.
Feb 28, 2009 | Washing Machines
Washing Machines Logo
493 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
