Question about Garland H283 Gas Kitchen Range
Garland range we have the huge 6 burner dual oven and griddle. no manual but smell gas and gas alarm went off. how do you disconnect the line cord/ gas line?
    Scholar:
  • 68 Answers
The unit does not have it's own shut-off. You'll need to shut it off at the building's supply. The plumber surely installed a valve right behind the unit.
Make sure a technician inspects the gas supply tubing for the OVEN pilots. They run from the front manifold, to the back of the oven, down the back, and under a shield. They tend to go bad.
Posted on May 30, 2008
Do older garland gas stoves need a conversion kit or can they be adjusted from nat to propane
They must be converted. New burner orifaces for burners, griddle, and oven and a new regulator for the gas valve.
Apr 30, 2014 | Garland Kitchen Ranges
Griddle top replacement
well this is different, but sounds like fun. I would just Repair the gas griddle you have. from the sound of it you need to replace the 3 or 4 tstats that control the griddle. If you are in a Metro area you can find a dealer for Robert Shaw and get the parts you need. but you may also start at http://www.garland-group.com/. everything there will be newer but you will be able ask about where the data plate is and then get parts lists. call a small comercial kitchen repair company and ask for help there too.
Jan 29, 2012 | Garland Ovens
Black Garland H283 convert to Electric ignition?
Is there a kit to convert an older Garland 6 burner, double oven, griddle and salamander to electronic gas ignition?
Sep 25, 2008 | Garland H283 Gas Kitchen Range
Garland range griddle top
make sure your unit is leval if you have alarge build up you will have to remove griddle and claen then reinstall
Sep 08, 2008 | Garland PS-36G-4-26 Gas Kitchen Range
Parts manual
Hi, you can call Garland Range at 1.800.424.2411, and talk to the parts department, or you can visit www.garland-group.com and in the top right corner is a "contacts" tab, and you can email them your request. Hope that helps.
Jun 02, 2008 | Garland H286 Gas Kitchen Range
Smell of gas and question on cleaning
I recommend cleaning heavy cast burners with a wire brush. If for some reason, (moisture in gas), the burner holes are corroded and slightly clog, use a perfectly size drill, and clean the holes BY HAND. Do not use the power tool. Just twist the bit by hand.
Commercial equipment is designed to be under a hood. When installed in a residential application, I would very much expect for the unit to "smell". I would recommend taking the time or money to verify supply gas pressure, and install a regulator if needed. Most all supplies are higher than the equipment is spec'd for, so a regulator, that is properly adjusted, would help solve your issues. Also a reg would save you money on fuel through the years.
May 28, 2008 | Garland H283 Gas Kitchen Range
60" double oven gas Garland stove
We use a Garland from the 1960's and pilot lights ARE scary and should make you nervous. This is why they are no longer allowed in new gas ranges. I mounted an inline gas shut off to the stove where the gas enters (on mine this is right in front on the left side). It turns on and off like a burner and when we are done cooking we simply shut off the gas there. To light the burners or the stove I use one of those long reach lighters. I go to bed knowing that NO gas is coming in.
We love the stove, it makes cooking more fun.
Good Luck!
Oct 24, 2007 | Garland H283 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
236 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
