Question about Whirlpool Dryers
I have a Whirlpool dryer that won't heat, how do I know if it's the heating element or a thermostat fuse?
    President:
  • 1,197 Answers
Unplug the dryer and the first thing to do is check for the presence of 220 volts at the wall outlet. If you lost one leg of the 220 volts, it is possible for your dryer to run but there will not be any heat. Once you verified there is definitely 220 volts at the wall outlet, remove the rear cover. On the lower right hand side you will see a silver canister which contains the heating element. Remove the lower two wires directly from the heating element and check this for continuity. If it is good, on the left hand side of the same canister they often install a thermal safety which may have tripped. Do the same test as with the heating element. Remove the wires and test the thermal safety for continuity. If this is good, move to the blower housing on the left side of the exhaust vent and look for a white piece of plastic which has two wires on it. Remove these two wires and check this item for continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
Posted on Oct 09, 2010
I have a whirlpool gold model number geq9800lw0. I need to know how the thermal fuse and cut off are wired with the heating element. Think I may have gotten some wires mixed up.
They are usually wired in series, the wire comes from the control to the thermal fuse, then from the fuse to the thermostat and then from the thermostat to the heating element, then from the heating element to the control.
Jun 06, 2017 | Whirlpool Dryers
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Dryer spns but there is no heat
probally the heeting element
Mar 10, 2015 | Samsung Dryers
I have a Whirlpool electric dryer M/ WEP5300o that will not heat. I have replaced the Cycling Thermostat, High limit thermostat, Thermal fuse and heating element. It still doesn't heat. There are
If you have fuses on your electric panel it normally uses 2 fuses, 1 for electric power 1 for heat. The same may be true on the circuit board panel check this to eliminate this possibility
Feb 02, 2013 | Whirlpool Dryers
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    MY DRYER WON'T HEAT.
    This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
    Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
    Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
    Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
    Jun 17, 2011 | Whirlpool Dryers
    Dryer goes on and spins but no heat. I've opened up the back but what now? Is there a specific part that if blown would cut off the heat? Model is a small one - probably cost about $300 - don't know the...
    The thermal cut-off at the top of the heater duct/housing blows when the high-limit thermostat below it fails to cycle the heating element on and off properly to regulate the heater temperature. This thermal cut-off along with high-limit thermostat including the cycling thermostat on the blower housing are wired in series with the heating element and power to it is cut when the thermal cut-off blows as a safety feature to prevent fire. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions in troubleshooting this problem.
    Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
    Mar 11, 2011 | Roper REX4634KQ Electric Dryer
    Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
    It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
    Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
    Feb 12, 2011 | Dryers
    My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
    dryer_heating-element.jpg Heating Element
    dryer_thermal-fuse.jpg Thermal Fuse
    dryer_thermostat.jpg Thermostat
    dryer_timer.jpg Timer motor
    A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
    Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
    Whirlpool leb6000pq1 not heating
    Thermostat controls heat. There is also a
    motor centrifulgal switch, in the element
    circuit, that the motor closes to insure
    the motor is turning. Try another heat
    setting. There is more than one
    thermostat. You may have blown the
    'thermal fuse' too, which requires
    replacement. The elecment has a contact in
    the 'timer' circuit too.
    It is possible that your element has
    failed also.
    Tripped high limit. Must clean the lint
    filter and the exhaust vent tube and all
    the way in to the dryer. Hot air exit is
    restricted.
    Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
    Dryers Logo
    49 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
