Question about NAD T163 Amplifier
When switching from anoglog audio into digital audio so there will be a strong percussion in subwoofer
    Genius:
  • 1,175 Answers
You may want to contact NAD tech support.
You can do that thru their website
Posted on Oct 09, 2010
My subwoofer keep showing a red light when i switch it on, could it be a fuse fault?
Probably not. The red light indicate idle mode. The woofer might have an auto-sense switch. When activated the subwoofer turns on when an audio signal is sensed at the subwoofer input.
Such switches often have three positions:
Idle (Somewhat off, but not quite)
Auto (Turns on the woofer when audio signal is detected)
Allways on. (The woofer is allways on - you might hear humm in the woofer when no audio signal is present)
Apr 24, 2016 | Audio Players & Recorders
Super glue splashed on my laptop screen how do i remove it
Stephanie it's very difficult. The glue is super strong and the screen is delicate. I hope you wiped it off immediately for much much less damage.
Dec 25, 2013 | Jl Audio 12W3 Car Subwoofer
I Have an spl audio amp 520 watt and when it turns on it automatically goes to red which is protect. what could be causing this problem
It could be 3 things. There could be a short somewhere, your ground isn't strong enough, or you accidently switched up the ground line and the power line on the amp. Since the fuses aren't blown I would say that your ground isn't strong enough.
May 01, 2011 | SPL Car Audio & Video
Pioneer VSX-815-K receiver with sub in standby
Have you looked in the manual?
No sound from subwoofer. • Make sure the subwoofer is switched on.
• If the subwoofer has a volume knob, make sure it’s turned up.
• The Dolby Digital or DTS source you are listening to may not have an LFE channel.
• Switch the subwoofer setting in Speaker Setting on page 40 to YES or PLUS.
• Switch the LFE Attenuator Setup on page 61 to LFEATT 0 or LFEATT 10.
May 13, 2010 | Pioneer VSX-815-K Receiver
THE SURROUND RIPPED ON MINE. ITS A 10" JL W6.
use some extremly strong yet pliable adhesive to hold it together eventualy you will have to recone it. check out ebay for recone kit
Apr 04, 2010 | Jl Audio 13W7 Car Subwoofer
Is a 1000.1 kicker amp a match for digital audio subwoofer 1500
it should work fine the watts sould be pretty close, more watts more sound, you dont need to have same brands to run car audio
Nov 29, 2009 | Digital Audio Car Audio & Video
Hooking up my Digital audio subwoofers
How did you connect it to your receiver?
Jun 14, 2009 | Mirage LF100 Subwoofer
Need shematics for yamaha dd50 drum machine
could you send schematics of yamaha dd 50 digital percussion? thank you
Jun 21, 2008 | Yamaha Audio Players & Recorders
Orange light
I have the same speaker and it sounds like its behaving properly.
if you look on the back of the amp, you will find a switch that allows the speaker to automatically switch the speaker on or off based on the level of the audio coming from the tuner that it is attached to. If the switch is set to the auto mode, then it will listen for audio on the line and if the signal level coming into the subwoofer is high enough, the amplifier in the subwoofer will turn on and play. If the signal is not strong or loud enough, then the subwoofer will not turn on. There are two solutions to getting the speaker to work.
1. When you turn on the tuner or audio source that is feeding the Subwoofer speaker, you will need to turn it up loud enough to trigger the circuit in the subwoofer to switch on.
2. Alternatively, you can bypass the automatic circuit and set it to the "ON position all the time. In this position the subwoofer is always ready and waiting and should play any signal that is fed to it regardless of the loudness or volume of sound from the tuner. The switch is located on the back of the speaker cabinet just to the right of the red and black speaker wire connections. It is labeled "AUTO" and the switch positions are labeled ON and OFF.
Hope this helps!
Jul 09, 2007 | Acoustic Research S112PS Subwoofer
NAD T163 Amplifier Logo
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
