Question about Avanti Hot and Cold Water Cooler
Substitute water refill..
Since the water reffil bottle is costly, isn't there any other device from which i myself can refill bottle without buying a new one?
  • hemant238198 Jun 12, 2008
    thanks buddy....but is der any refill bottle available which can be filled manually by me rather than buying a new 1 as it is very costlier......
  • 8,596 Answers
I'm not sure what you're asking. You can run a plastic tube from a faucet head to the reservoir of this water machine - liable to get messy/wet if not handled properly. You can also puncture a hole in the water bottle - toward the bottom (careful) and tape a plastic tube from the water bottle to nowhere - be sure to tape the end shut so you don't experience leakage - will get annoying over tiem.
Just call the manufacturer/distributor - if they can't fix it or replace it under warranty, just buy a new one.
Posted on May 30, 2008
How to reffil ink cartridge
I don't recommend refilling ink cartridges for a multitude of reasons.
The ink isn't always the correct quality/viscosity so the heads can get blocked. It only takes one cartridge to be refilled badly to go on and ruin your printer. The process can be very messy.
Mar 26, 2014 | Office Equipment & Supplies
Printronix p7005 reffil
do not use refill cartridge printing may be affected. use only new and exact cartdridge
Nov 08, 2013 | Printronix P7005 Matrix Printer
What kind of coolant should be used for the 1998 Oldsmobile Regency?
By 1998 General Motors was using Dexcool. Stick with whatever color coolant you have in the vehicle if your just topping up. If flushing the system you may refill it with either dexcool or conventional coolant. Although I believe the rec. coolant for your vehicle is dexcool which is a pinkish color.
Jan 09, 2011 | 1998 Oldsmobile Regency
I refilled my cartidge. my printer model is D1660 Hp inkjet. now, problem is that only green colours comes out. if i print red it come by green colour. what will i do now?
you had mixed colour while reffiling cartriage. open cartriage with knife or some other thing which can open it there is spong in it .wash with water and soap then dry then insert spong in close cartriage cover the feviquick and then refill properly and try
Jan 01, 2011 | HP D1660 InkJet Printer
I rifil canon Fax -JX 201. 1st time It Good worked. But 2nd Refill icant get photocopy; But it say "No ink" .How to Reset that error
by refilling the ink crg. you probably destroy head electronics. Buy new one ORIGINAL, and try then.If you must refill ink be carefull, rather buy new reffiled ink, where the chip is resetted.
Hope that helps!
Aug 10, 2010 | Canon FAX-JX200
Water in the fuel tank wrangler 97
Sorry the isn't a drain plug on the fuel tank. Try this go to walmart or home depot and buy a kerosene can hand pump plastic cost $3 to $6 remove the hose coming from refill to tank cut off a piece of old water hose approx.5ft insert into tank from opening insert hard plastic portion of hand pump into water hose have something large enough to contain the fuel and start pumping open valve on pump to release pressure may have to pump several times to get it flowing good do not try to **** on hose pump will work once all gone reconnect hose and refill fuel with one bottle of Lucas fuel treatment and one bottle of Marvel Mistery Oil drive it all out refill fuel again with one last bottle of Lucas fuel treatment. wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Apr 22, 2009 | 1995 Jeep Wrangler
Refill toner konic minolta 1350w
i just installed a new cartridge , but i still have vertical streaks on my sheets
do i need to get the toner clean , and what product do i use ?
thanks again for you time / help
Mar 19, 2008 | Konica Minolta PagePro 1350W Laser Printer
Avanti Hot and Cold Water Cooler Logo
248 people viewed this question
Top Avanti Water Filters & Coolers Experts
John Tripp
John Tripp
john h
Are you an Avanti Water Filter and Cooler Expert? Answer questions, earn points and help others
