Partial horizontal collapse. Nu-tec Model NTT-829A
I have replaced IC Tda3654. I have replaced all electrolytic capacitors in high voltage circuitry and som of the non polarized cap's. High wattage resistor 436 on pc board measures 4.6k ohms but cannot determine what the actual resistance is supposed to be as the colors are totally discolored due to the heat the resistor dissapates. Do you know where I can get a circuit diagram or do you have any ideas to rectify problem?
    Sergeant:
  • 280 Answers
If you have retrace lines I would recheck all caps around the vertical IC 100@16 is the most common 47@35 and 220@35
Posted on May 30, 2008
No power out
You have no power because you didn't fix 2 or 3 electrolytic capacitors when you saw warning signs. Warning signs start as horizontal lines every half inch or so. Black bars on the top and bottom, then collapsing to a horizontal line, then complete failure.
You will need a horizontal output transistor, the aforementioned electrolytic capacitors, a voltage rectifier, possibly a high voltage coil called a flyback transformer, wire wound resistor, maybe a low resistance resistor, maybe a high voltage capacitor. In some tvs you need an EPROM ic. I hope you can find someone with the knowledge and expertise these days when the modern throwaway society put almost all electronic repair shops out of business. It may cost about $300 - $400 to get repaired or you can get a modern flat-screen tv for $800 - $1,000 and reinvest that money.
Nov 27, 2013 | Televison & Video
Tv on appears black screen with a bright horizonal line in the middle sometimes with voice
You will have to resolder the vertical IC and in most cases replace any capacitor that is near and next to the vertical IC. There may be three capacitors that will be replaced, And while you are in the process of reworking the board inspect for any and all grounds that may need resoldered. You will have to look very close to find these. And you should search the deflection side of the board for two capacitors that have a 160 volt to 250 volts at 1MF, or 2.2 mf or 4.7Mf. By now these little guys are weak and need replaced. Thanks for asking and show a few hands of support!
Jan 27, 2011 | Panasonic CT-32G23 32" TV
TV has a line across middle from left to right
It depends what part was damaged in Horizontal section. Here in Philippines labor costs for this size of TV is ranging from $50 to $150.
Feb 27, 2010 | Televison & Video
My TV picture has collapsed to a single horizontal line
If it is an standar analog tv, I'm sorry to tell you but, is time to get a new one.
Dec 05, 2009 | Panasonic Televison & Video
TDA3653 keeps blowing when the TV is switch ON
Without checking components associated with the TDA3653, the exact cause is impossible to say.
This IC has extensive built in protection circuitry that should protect it from overloads caused by such things as shorted turns in the vertical deflection coil, or from faults with any associated components, e.g. open/shorted resistors/diodes/capacitors.
The following data sheet describes this IC in detail:
http://www.datasheetcatalog.org/datasheet/philips/TDA3653.pdf
Therefore as the IC keeps failing at switch on, and if no other components are failing or suffering damage, suspicion must fall on the supply voltage delivered to Pin 9 and Pin 6 being excessively high (or spiked) and thus causing a rapid demise of the IC. As most LV (low voltage) supply voltages in TVs are derived from a common regulated source, this would imply that the power supply circuitry itself may be faulty - dried out electrolytic capacitors being prime suspects.
However, as with any fault in complex circuitry such as this, there may be other causes including less logical ones such as dry joints or shorts in wiring or between PCB tracks.
Nov 23, 2009 | Sansui Televison & Video
Horizontal line across screen
HELLO
This is called "Field Collapse". Line collapse is different (a single vertical line) in the centre of the screen.
But field collapse is usually a fault in the field circuit (possibly a field output IC has gone short circuit) or electrolytic capacitors have dried out. The same can happen in a CRT TV - looks as if LCD panels are the same way! I think you will have to take this to a service centre.
GOOD LUCK! (:-)
Sep 12, 2009 | Memorex Televison & Video
Thin horizontal line accross screen
if the screen is totally black and only white horizontal line appear on the screen, check the vertical section if there is supply voltage on the vertical IC, and if there is none check the source of some open resistor connected to that IC. if there is supply voltage check all electrolytic capacitors connected in that vertical IC and it is better to replaced them all they are very cheap. and if it is still not working replace the vertical IC. post some comments if it is still not working and let see what we can do..
Aug 11, 2008 | Televison & Video
Proscan PS27123 TV Problem
just to be sure, is it vertical or horizontal? Anyway, if it is vertical, it could point out to the vertical Ic section or some loose contacts along the lines. If it is horizontal, it could be a filter capacitor along the horizontal Circuitry. Mark the high voltage capacitors along the high voltage sections.
regards,
chris
Jul 23, 2008 | Proscan PS27123 TV
Sony tv no picture only horizontal line
The probable defective part is the vertical IC. If changing that does not resolve the problem, check the capacitors in the same circuit. Also, check for the proper voltages at the vertical IC. If the IC is not being fed its power, it won't work either. I don't have a listing for your specific model. If you can post the vertical IC part number (LA7837 for example), I can list the voltages per pin.
Dan
Apr 09, 2008 | Televison & Video
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
