Question about HP LaserJet 1320 Printer
Toner is depositing itself on the edges of the paper after printing. Its real thick and will actually flake off the page. It just started doing this for no reason.
  • 35 Answers
The toner is built up on the toner.
most of the time you can not clean it off and keep it off because of the scratches on the teflon sleave .
and also replace the toner "stay away from rebuilt toners "use only hp cartridges.
Posted on May 30, 2008
Ink flaking off printed labels
your problem is not good fusing. try with a different fuser.
Apr 10, 2013 | Oki Brand Oki 62433501 C711n Laser...
I have an oki c9650 when I print on cardstock the blacks become bubbly and flake off, but only when printing on cardstock
Set it or computer, whatever you are using to cardstock, or it may be called thick,there are multiple selections depending on the media. Beacuase thick paper requires slower speed and hotter fuseing.
Sep 26, 2012 | OKI C9650HDN Led Printer
Left edge black on hp laserjet printer
Fuser teflon sleeve got damaged, replace it.. (only professionals can do this activity) if its not available go for new fuser assembly..
Jul 31, 2012 | HP "LaserJet P2035n Printer"
I'm printing on 110 lb card stock and the toner gets crispy..and actually flakes off on the edges and sometimes leaves smears and clumps of black or burnt toner on the paper. It prints fine on 20 lb paper...
could be the fuser but there is a setting for heavy paper or card stock which will slow it down and increase the heat. depends on your model as to where this can be changed.
Jul 27, 2017 | HP Color LaserJet 2600n Printer
My printer is flaking. i am printing a heavy color image on a kyocera fs c8026n. any help?
If by "flaking" you mean that the print is rubbing or flaking off then there are 2 possibilities. If you are using thicker than standard 20lb bond paper then when setting up the print job make sure you are selecting thick paper on your paper setting. This is a common problem if your paper is thicker, shiny or anything other than standard.
The other possibility would be a fuser defect of some type. But that would tend to affect standard black and white prints as well.
Try the thick paper setting as it will slow down the paper speed thru the fuser and will "fix" the toner to the paper better.
Jan 15, 2010 | Kyocera FS-C8026N Laser Printer
Hp2600n printer
Is the toner fused to the paper, or 'loose', and can be rubbed of easily. Are there 'flakes' of toner, that may or may not be loose?
If the toner is fused, the cartridges are likely to be leaking toner - especially if they are remanufactured - not easy to get right, and even more difficult to get right if 'home refilled'.
Solution to this is replace cartridges, or if these are new return them to supplier as faulty.
If there are 'flakes', it is likely to be the fuser that is contaminated with toner that has ot fused to previous pages - usually as a result of using the wrong type of media, or setting the wrong paper type when printing on thick media.
Fuser can be cleaned, or in extreme cases replaced.
Sep 10, 2008 | HP Color LaserJet 2600n Printer
Toner being deposited on back of page
point check
1.Hallo your rollers are dirty and smudged
2.Is your fuser unit O.k (clean) your paper good quality or are you using coated paper the wrong side? thereby staining the fuser unit (the hot part of the printer)
4. Most unlikely but have u ever turned your printer upside down??? or excess sideways tilt thereby releasing waste toner from the bottom of the printer to the roof then to your paper???
if all is nay then remove all toners and give your machine a gool blowout
Apr 26, 2008 | Epson Aculaser C1100 Printer
Patchy Prints
I believe that the Heat roller in the Fuser has a build up of toner on it(in some areas) and as a result is not fully fusing the toner into the paper. when you use a thick setting you are actually slowing the speed down to allow more heat to the toner. the thicker paper causes more pressure allowing the toner to fuse properly. I would say you need a new Heat roller and possibley a pressure roller. You could try running 20 copies of a blank white page. Sometimes this will help. Poor fusing can also cause a previous image to come up on the next page or repeat itself down the page. A service call is in order if this does not work.
Hope this helps
Dave T
Mar 29, 2008 | Ricoh 6513 Copier
Specific PDF Document/Specific Print Area Black Toner Not Fusing And Flakes Off
Without a doubt you have a problem with the fuser.
What that is caused from is buildup over time of ink on the heat roller. The teflon coating wears some and the ink sticks to the aluminum instead of pealing off onto the paper.
You then do not get enough heat or perssure to "fuse" the image into the paper.
Replacine the fuser will correct the problem.
Feb 03, 2008 | Xerox Phaser 7300DN Laser Printer
Erratic black fusing
I'm not real sure about how the software separates the colors, but I believe there's a way to choose a color as all colors combined to make black, or simple black.
I'm not sure if I'm making any sense, but if the printer is using all the colors to layer up and make black, then it would be a pretty thick coating and that might cause it to flake off.
Oct 30, 2007 | Xerox Phaser 7700 Laser Printer
HP LaserJet 1320 Printer Logo
111 people viewed this question
Ben Johnson
