Question about Acer Aspire 4720 Notebook
In my hap always showing consider replacing your battery.. how i can solve tis problem ...
  • 2,567 Answers
Seems that your laptop's battery is defective & needs to be replaced.
To be sure, you can perform the following diagnosis:
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 09, 2010
My Samsung Galaxy Tab P6200 is gone unexpectedly and cannot be switch on and i try charging it and it shows only danger sign.what should i do please? Read more: My Samsung Galaxy Tab P6200 is gone...
My first guess would be you have a broken battery. Try to open it and measure the battery. If it's above 3.7V, it is fine. Then you have to consider that your motherboard is broken. You should always try to replace a broken part yourself first. search model name plus "repair guide" on any search engine.They will show details about about part replacement etc. in detail. There are other websites that sell all the replacement parts, one of the bigger ones is http://portatronics.com (646) 797 2838.
Jan 04, 2014 | Samsung Galaxy Tab Gt-p6200 7.0 Android...
My battery telling me; "consider
That will be the laptop measuring the energy stored in your battery and it is less than the level it is set at.
It doesn't mean it will fail imminently just that it is not as good as it was when new.
Jan 17, 2011 | Computers & Internet
Hi, Can I use rechargeable lithium-ion batteries in my Fuji S1730 camera. Thank you. Roy.
Hi Roy,
If your camera uses normal AA or AAA batteries you will have no problems with the rechargeable batteries. If you are considering to buy rechargeable batteries always try to buy the higher mAh range batteries. The higher the mAh the longer battery power will last.
Feel free to share if this solved your question!
Regards
Nov 29, 2010 | Cameras
My Dell Inspiron 1525 is now around 2 years old and works only for 15 or 20 minutes after plugged out.Also on battery symbol, it displays a message saying "consider replacing your battery" and show a cross...
Don't worry just replace the battery of the laptop and your problem will be fixed.
It is because your laptop's battery has become old.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 14, 2010 | Computers & Internet
My nikon camara zoom & Flash not happing
Ensure the battery is ok and charges to its max, try with a newer battery.
Oct 14, 2009 | Nikon Coolpix 4100 Digital Camera
Unit increases loudness on own
This has happed to me on several occasions. Try replacing the remote's batteries. That solved it every time.
Apr 10, 2009 | Harman Kardon AVR 320 Receiver
Problem with my k800i
the firmware might have got corrupted this might of happened due to virus attack or due to sudden removal of the battery when the phone is on or due to sudden switch off of the phone when the battery charge was low ...
this firmware problem can be solved by giving the restore factory settings(reset) ...
after this your problems will be solved ....
if the same problem persists then you must take your cell to flashing .....(there is a less chance to do this , 99% sure your problem will be solved in the previous step only )
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 06, 2008 | Cell Phones
Press F4
svjyrat
"always message to press F4 at the time of star up". this problem happen when CMOS detect any error. is also happen if CMOS battery fail (Chack sum error).
to solve this problem at first check CMOS battery (it voltage less then 3V or not) if it bad then replace it. u can buy this battery form any computer accessories shope.
or if u not connect floppy drive, and controller enable. if u desable floppy drive contoller from CMOS setup (in intel mother board is show BIOS setup) then this problem solved.
Jul 03, 2008 | Intel Motherboard
Acer Aspire 4720 Notebook Logo
260 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
