Question about Dryers
I have a Rinnai RDT-50S. It is displaying code 90. I have cleaned both the intake filter as well as the lint filter assembly (all four pieces.) I am at my wit's end. What else could cause this fault to happen?
  • 864 Answers
SOURCE: Bosch Axxis dryer - lint filter indicator lights up
Make sure the exhaust vent duct is clean all the way to the outlet.
Posted on Nov 11, 2009
  • 178 Answers
SOURCE: DCVH515 GE Gas Dryer
The sensor in the filter "PATH" is actually located past the screen. It measures the amount of air flow passing through the exhaust cavity going outside. My suggestion is to clean the airflow duct from right past the lint filter all the way out side. It is recommended that this be done once a year for optimal performance. If this doesn't work, let me know.
Posted on Mar 16, 2008
SOURCE: Bosch Nexxt dryer WTMC6300US won't start;
For some reason my display showed the ''key'' icon. I must have switched it to lock somehow...I went through the menu,switched it to off and everything works now! Hope this helps
Posted on Jul 03, 2009
SOURCE: Lint Filter Light comes on and cycle is interupted
I just found that the filter itself was not allowing airflow- I tested by blowing through it with my mouth- no airflow. I cleaned it with a high pressure air hose and noticed that the flow is much better now. I cleaned it by hand several times, and washing in water (which may have made theproblem).
Posted on Sep 11, 2009
marka19
  • 1430 Answers
SOURCE: my dryer displays the message
You will need to clean it out. Try this link it should help http://appliancehelponline.com/dryercleaningvideo.html
Posted on Sep 15, 2010
Code 12 is displayed on unit-- directing to a combustion air problem
Code 12 is flame failure check out any over heat sensors
Oct 11, 2016 | Rinnai Heating & Cooling
Oe code. Will not drain. Steps to fix?
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 30, 2011 | LG LDS4821 24 in. Built-in Dishwasher
I am getting an OE code on my dishwasher
Hi
Daniel
Aug 24, 2011 | LG LDF6810ST Stainless Steel Built-in...
I have a Convector 417 RC-417-80 that starts fine but after about 5 minutes stops working. Any ideas?
Steve, there are a several of basic things that can cause this problem.
1. Air filter is clogged. Turn electrical part of unit OFF, Remove and Clean Filter, if necessary.
2. Air intake obstruction. Look for air intake obstruction around the front of the heater.
3. If your unit is a flue-less heater, Oxygen Depletion Sensor (ODS) may be partially clogged with
dust, link or pet air. Clean Pilot Assembly using canned compressed air with a straw nozzle (like
you clean your computer with).
4. Gas pressure fluctuation to the heater. This will require a service call from an authorized Rinnai
Service Technician,
Hope this helped you to troubleshoot and solve the problem.
Jul 11, 2011 | Rinnai Heating & Cooling
Have a Rinnai Energy Saver 551 F gas heater. When the heater is switched on it then turns itself off after approximately 5 minutes
Stuart, I beleive the model number you have is Rinnai, Model 151 Portable Gas Heater (Meaning it's flue-less). If that is the case, the Oxygen Depletion Sensor (ODS), which is part of the Pilot, may be clogged with dust, lint, pet hair, etc. In which case, cleaning it, with canned compressed air with a straw nozzle (like you clean your computer with) can solve the problem. Also, cleaning the entire interior of the heater is a prudent thing to do, at least once a year. A vacuum cleaner that has a hose and brush attachment works well for this. To assist you, I have included a link to "How to clean your Pilot and Burner Assembly" Demonstration, as well as a link to the Owner's Manual for you Model Rinnai Portable Gas Heater.
Cleaning Demonstration: http://www.desatech.com/techDocs/Cleaning%20Demonstrations.pdf
Owner's Manual: http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/Portable_Radiant_Convectors.pdf
I hope this has helped you troubleshoot and solve the problem. Please let me know. Cheers!
Jun 21, 2011 | Rinnai Heating & Cooling
Heater keeps shutting off what could it be cant find manual to help
Use this manual to assist you in troubleshooting. http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
The manual will help you isolate the problem.
Things than can cause your symptoms:
1. Pump pressure incorrect
2. Dirty air intake, air output
and/or lint filter
3. Dirty fuel filter
4. Obstruction in nozzle
5. Photocell assembly not properly
installed (not seeing the flame)
6. Dirty photocell lens
7. Bad electrical connection between
photocell and ignition
control assembly
8. Defective photocell
9. Defective ignition control
assembly
10.Line voltage is below 108V or
above 132v
REMEDY corrosponds with 1 - 10 above
1. Fill tank with kerosene
2. See Pump Pressure Adjustment,
page 10
3. See Fuel Filter, page 11
4. See Nozzle Assembly, page 12
5. Drain and flush fuel tank with
clean kerosene. See Storing,
Transporting or Shipping,
page 7
6. Check electrical connections.
See Wiring Diagrams, page 16
7. Replace ignitor, see page 11
8. Replace ignition control
assembly
9. Check for proper line voltage
1. See Pump Pressure Adjustment,
page 10
2. See Air Output, Air Intake and
Lint Filters, page 10
5. Make sure photocell boot is
properly seated in bracket
6. Clean photocell lens
7. Check electrical connections.
8. Replace photocell
9. Replace ignition control
assembly
10.Check for proper line voltage.
Disconnect power equipment
that may be used on same
line
Thanks for choosing FixYa,
Kelly
Jan 09, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
My Rinnai says not to use it without an air filter and to clean the air filter once a week--but I can't see an air filter. Is it possible that it was installed without one?
If you have a RHFE263, 431 or 556, the air filter is located at the top in the seam where the wall trim piece attaches to the heater. It looks like a dryer lint filter.
Feb 15, 2010 | Rinnai EnergySaver 556 Air Conditioner
Rinnai 431 wont start
You could have something as simple as a blocked flue pipe. Check outside and make sure the pipe is clear of ice or snow. Check the circulating fan and filter for lint. Be sure the lovers on the front of the stove are open and clean of lint.
Tom Hawkins
Apr 07, 2009 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Rinnai Heater - error message "12"
An error code of 12 on your heater means a flame failure has occured. It could be the following: Flame Rod dirty, Obstruction in burner, improper gas pressure, or a bad ignitor board. I am suggesting you get a technician who is familiar with Rinnai products to check out the above items.
May 25, 2008 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Dryers Logo
472 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
