Question about Xerox Phaser 8560DN Laser Printer
Xerox 8560 Error 09.037.45:8982
My mahine gives this error and i dont know waht is it. Can you help me ???
Tnx in advance.
  • Anonymous Apr 03, 2009
    used generic (cheaper) yellow ink and it's jammed in the chute and we can't get it out....
  • 3 Answers
Don't believe any of the misinformation about Xerox 8560 , 8570 , 8870 inks not loading or being rejected at the at the ink loader gateway. There is a very simple solution to getting the printer to accept any and all ink no matter if it is from another region or starter pack. There is a plastic pin that pops up at the bottom of the ink loader when you begin to drop or place the ink down into it - you can easily circumvent this. If/When the pin pops up (or it just stays up), you us a small magnet and place it down the right side of the loader (move it back and forth until you find the sweetspot) and you will hear a loud click and the pin for that specific loader will release and drop down. Now here is the trick-before the pin pops up again, use your finger from your other hand to hold the pin down, then use your other hand (as the magnet is no longer needed because your holding the pin down) and grab the appropriate ink cube and quickly place it in the loader while pulling your finger out and slide it down the channel . The pin usually moves up very slowly giving enough time to do this-if it doesn't, just repeat the process. Or instead of using your finger to hold the pin down, get a pencil with eraser on the end or small spatula (something thin enough) so you can hold the pin down from within the channel-way. That way nothing(meaning your finger) will get in the way of putting the ink cube into the loading space.
Never believe what the manufacturer tells you-I've been doing this with my 8570 and have no problems.
Posted on Jun 13, 2013
  • rsbc
    rsbc Jun 13, 2013
    President:
  • 2,072 Answers
That is a yellow ink stick fault.
Most likely one of the yellow sticks did not advance properly, or one is cracked or simply in a bit crooked.
If you used sticks from another model number, they would not have the right grooves in them to make the switch on the ink loader.
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8560 ink sticks jammed in the ink load chutes. If non 8560 ink sticks, whether manufactured by Xerox or by a non-Xerox ink vendor, caused the ink sick jam, contact support to place a service call.
Posted on May 30, 2008
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Feb 26, 2015 | Xerox Phaser 8560/YN Printer
What is error code "08,035.42:130169" on a Xerox 8560 mean
8,035.42: The Media Drive stalled while moving the cap/wipe Up.
Usual cause of these codes is a broken drive assembly or a broken mounting base of the motor or the wiper is stacked.
Aug 18, 2014 | Xerox Phaser 8560DN Laser Printer
ERROR MESSAGE PHASER 8560 09,006.41:150694
9,006.41: The magenta ink melt heater is On, but ink is not dripping.
Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink cubes.
Apr 07, 2014 | Xerox Phaser 8560MFP Laser Printer
08,030.46:45203 error code with xerox 8560 printer
Are there obstructions or spilled ink on the Wiper Blade, the Head Tilt Gear drive path, or under the Printhead?
Is the Waste Tray overfilled?
Clean the inside of the printer and retest
Mar 10, 2014 | Xerox Office Equipment & Supplies
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Feb 07, 2014 | Xerox Phaser 8500/DN Printer
On the 8560, what does the error code 07,010.43:14070 mean??
In the Xerox support website that error indicates that the printer needs to be turned off and call for xerox assistance. Does not specify the problem.
Although, this website refers to this problem.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/25/xerox-phaser-8400-8500-8550-8560-07010-43-error-message/
If the printer has only one year old, the best solution will be to call for xerox assistance because it is under warranty.... I think...
Aug 08, 2012 | Xerox Phaser 8560MFP Laser Printer
INVALID SIM
This may be because of your damaged SIM. Try the following:
1. Check whether your SIM is rejected by just putting the same SIM in another phone. Also, check if your SIM is a valid GSM compatible SIM.
2. Check if that your phones SIM slot is fully operational.
3. Check if you have correctly inserted the SIM.
Hope this may help you. Happy New Year to you too.
Jan 01, 2012 | Nokia Cell Phones
Invalid sim
If the Phone says Invalid Sim means it locked to Network ,You need to Unlock it...get the Unlock code from the site Superunlockcodes.com and get the Free unlocking instructions at here Mobileunlockguide.com/nokia-5130 and Unlock it step by step....That is Nokia 5130 not S5130,there is not model like that in Nokia.
Jan 01, 2012 | Cell Phones
Xerox Phaser  8560DN Laser Printer Logo
931 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
