Question about Biozone 500 Air Purifier
I was considering Biozone for restrooms etc and I assumed,as your info.says that it would be odour free?Some I have seen are not odour free.Is it just a uv lamp system or is there some form of ozone generation??
  • 736 Answers
The UV lamp does produce some ozone .. this one specifies .04 ppm .. thats not very much but might be detectable as a slight fresh air odor .. some other types use electrostatic filtering and some even have strong ozone generators .. ozone does kill bacteria, fungus and such and will freshen the air removing many odors but is not considered healthy in large or concentrated amounts or for prolonged periods .. the UV lamp will also kill bacteria and fungus without producing so much ozone.
Purifying Method: Photoplasma, UV, ions, and ozone.
Posted on Oct 09, 2010
Testimonial: "Thank you for a prompt response."
    Problem Solver:
  • 8 Answers
Http://www.air-purifier.org explains how Biozone air purifiers work and some ozone is needed for odor elimination etc.
Posted on Oct 10, 2010
Replace lamp biozone 1000
Here's some Biozone lamp info http://www.air-purifier.org/orderform.html. Replacing the lamp is pretty simple, just remove the old lamp and install a new lamp and fuse if any.
Aug 31, 2012 | Biozone Standard 1000 Air Purifier
BIOZONE 1000 HAS NO POWER
Maybe it also needs a new fuse or power supply?
Mar 01, 2012 | Biozone Standard 1000 Air Purifier
I have a bleach smell when the unit is working. This takes away from overall effectiveness as I have to open doors to get the odour out. Is this normal.
If the unit hasn't been cleaned recently and that includes the filter, that may be the problem. Also, be sure to carefully remove and clean the glass plaques. Be sure they are totally dry before reinstalling them.
Hope this helps you solve the odor problem.
Mar 22, 2011 | Ecoquest Breeze AT Living Air Purifier
The blue lite fades to black after awhile after powering it up
It sounds like the lamp and maybe the fuse has gone bad and might need replacing. Here are some Biozone lamps and fuses http://www.air-purifier.org/orderform.html
Oct 11, 2010 | Biozone Travel Aire 250T Air Purifier
Repair info for oreck md# a260 unit ran fine and worked well until I heard popping noise from front of unit probably bad connection of high voltage to filter cartrage fan stopped working if i turn unit on...
It depends on what you paid for it.I checked out Oreck and they had no free downloads available for anything.Here is their customer service though to find out about parts,diagrams,etc.Some places will not sell parts to consumers,some will.Here is the link.
http://www.oreck.com/SiteMap
Jul 27, 2010 | Oreck (AIRCOM1WOI) Air Purifier
The fuse keeps blowing in my biozone 1500 induct unit.
get yourself a cheap multimetre, check for a short circut or open circut. this should be your first step. refere to google for info on short/open circuts. check the capasitors (small cylender things) for leakes or if the top is popped up on them. if so replace with the SAME. hope i was of some help
Aug 17, 2009 | Biozone InDuct 1500 Air Purifier
Under Counter Water Filter Leaking after Use Sometimes!
Got it! Your return line is clogged!
I have the same dispenser, and there are 3 tubes attached to it. One of them (black on mine) goes from the faucet to the drain pipe coming down from the sink. That line can get clogged over time with stuff coming out of your sink. You can probably disconnect that line at the drain pipe end and **** oput the connection and as much of the hose as you can get too., Reattach the line and you are done. Fire it up.
On my unit, we hear a dripping sound in the drain when the unit is charging. If you don't hear the dripping sound after using the unit, that line is probably clogged up!
See ya!
Everett
Mar 14, 2008 | Biozone Water Filters for Counter Top:...
Biozone 500 Air Purifier Logo
215 people viewed this question
Top Biozone Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Biozone Air Purifier Expert? Answer questions, earn points and help others
