Question about Samsung Audio Players & Recorders
My YP-Z5F was working fine until last week, only the On-Off button is working to control On and Off but other buttons won't respond. Even when I switch to hold mode, it doesn't show a lock icon on the screen. Besides, I also tried to connect it to my computer to see if it will work after it, the screen only show the battery chargin icon but not response on the screen indicating a USB connection, as well as my computer does not recognize any MP3 device...... Can anyone please help.... Thanks!!
  • Viii May 30, 2008
    Im afraid it didn;t help...
    the situation remains.
    and something even worse happen is that i found it although it was shown charging on the screen, it is actually not charging at all...
    I will keep trying your method but will there be anymore solutions??
    I have reset it for thousand times already..but its still the same..
    Thanks...
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 30, 2008
After 6 weeks, phone is dead
still warrentty time so contact ur uniden cordless phone dealer
Jul 19, 2009 | Uniden Cordless Phone
My Samsung YP-T9 had frozen
hold a-b button and menu buttom simultaniously
Dec 25, 2008 | Samsung Yepp YP-T9 Digital Media Player
Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Oct 11, 2008 | Samsung YP-Z5 MP3 Player
Samsung YP-Z5F
I've had various issues similar to those described, and can offer the following trouble-shooting and/or work-around tricks that I've had success with:
Sometimes, when I come to use it I find that it won't turn on at all, but it's most likely because it's been a while (several weeks) since the last time that I used it.  The battery does seem to lose its charge over this time.  All I do is to charge it up for several hours, (or even overnight).  It usually charges best by leaving the unit OFF when plugging in the USB cable to the PC, just like a cell phone does.
As for the problem with the PC recognizing it, sometimes it just takes a few minutes. I have winXP.
First, open MyComputer.  If the mp3 player doesn't show up as another drive after about 60 seconds, press the F5 key to 'refresh'.  Sometimes closing MyComputer, then re-opening it makes a difference, too.  You might also want to try a different USB connection, like using one in the back of the PC instead of the front (or vice-versa).
Sometimes, though, it doesn't hurt to just press the RESET button at the bottom side (6 o'clock position when holding it upright and facing you).  With it turned ON, I insert a paper clip that's been partially straightened out, holding it in for about 3 seconds.
Jul 30, 2008 | Samsung YP-Z5FA MP3 Player
Bush DVD 2038 DVD player
I contacted Bush custimer care and this is the reply I got:
We apologize for the inconvenience caused to you.
We would request you to kindly reset the remote control by following the steps mentioned below:
1. Remove the batteries and reinsert the batteries after 1 minute.
2. Press and hold the top, right and the bottom navigation button on the
remote control along with the number 1 button (as in 123) for 10sec.
It didn't work for me, but I have posted it on here, just in case it works from someone else
Feb 02, 2008 | Televison & Video
Yp-z5f MP3 PLAYER
i can't change my samsung mp3 YP-Z5F 2 GB and i don't have installation CD.So,how can i change and where can i download installation CD,If you don't mind , you can give me that CD,My account is nonamewai@gmail.com,
thanks you!~
Oct 19, 2007 | Samsung YP-Z5A MP3 Player
MY SAMSUNG YP-Z5F-PLAYER FREEZED!
Hi there. Have you tried the reset procedure, by pressing the tiny button under the player with a paper clip, or a pen's tip ? That might do it ! Please reply if it doesn't work, and give a bit more details on the exact player's behavior :) Thanks, cheebster.
Jun 18, 2007 | Samsung YP-Z5FZ (1 GB) MP3 Player
Samsung MP3 Player YP-Z5F
is there a reset button [pinhole] on the player??
should fix it
Apr 01, 2007 | Samsung YP-MT6X MP3 Player
Samsung YP - Z5F
Samsung YP-Z5F
Will not always switch on and when it does switch on will not respond to control panel
Jan 19, 2007 | Samsung YP-MT6X MP3 Player
62 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
