Question about Hoover Dryers
The heater in the dryer is not working - Hoover Dryers
    President:
  • 1,197 Answers
Unplug the dryer and the first thing to do is check for the presence of 220 volts at the wall outlet. If you lost one leg of the 220 volts, it is possible for your dryer to run but there will not be any heat. Once you verified there is definitely 220 volts at the wall outlet, remove the rear cover. On the lower right hand side you will see a silver canister which contains the heating element. Remove the lower two wires directly from the heating element and check this for continuity. If it is good, on the left hand side of the same canister they often install a thermal safety which may have tripped. Do the same test as with the heating element. Remove the wires and test the thermal safety for continuity. If this is good, move to the blower housing on the left side of the exhaust vent and look for a white piece of plastic which has two wires on it. Remove these two wires and check this item for continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer dryer-wont-heat repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
Posted on Oct 09, 2010
Was working and shut off. Will not start and I do not know if it has power because the inside light never worked.
These dryers are notorious for a loose blower wheel.
The thermal fuse is located to the right of the heater and is held to the side of the heater by the same screw that holds the heater element down:
themobilian_2973.jpgThis is a good dryer. Well worth fixing. I wrote about it HERE
Sep 06, 2011 | Maytag HYE3658AY Electric Dryer
Dryer works but has no heat. Voltage is good. Could it be the TCO?
I suspect that your heater strips in the dryer have burned out. Just to give you an idea, I have replaced my heater strips in my 40+ year Whirlpool dryer two additional times over the years. You will have to take the back off of the dryer after disconnection the 220V plug and examine the heater strips.
Nov 30, 2010 | Roper Dryers
My dryer is not rotating, heater is working. It is
sounds like a belt and the heating eliminate
Sep 26, 2009 | Dryers
When i try to turn my dryer on, it won't start
Assuming that you have an electric dryer, check the house electrical panel dryer-circuit breaker-pair. Push both off, then on. If they immediately trip off again, then you have a dead short circuit within the dryer. If they hold on, then try the dryer--if works,ok! If it doesn't work, recheck the breakers again--if tripped, a short circuit in the dryer heater circuit is probable. The dryer drum must be removed to gain access to the heater assembly.
Aug 23, 2009 | Dryers
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
No heat
there is a main dryer fuse and a heater box fuse,the heater box fuse is the small bimetal fuse on the heater box,replace that and you should be ok,let me know how it goes-mike
Oct 12, 2008 | Zanussi TC7114W Electric Dryer
Dryer not working
thermostat on top of dryer heater may need to be reset . Unplug and remove top and just push gently the thermostat (red) you may hear it click .now reset or perhaps a lead as broken to the dryer heater .
Jun 28, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Dryers Logo
70 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
