What does ' not support mode ' mean ? we have been running an xbox on the 'component' source all ok until now. thanks
  • 11,800 Answers
The resolution is too high. Take all connectors out and start the xbox unconnected leave it like that for 5 minutes then shut it down and reconnect it . try again - if even now it doesn't work the you will have to connect to composite (not component) plugs before trying again.
Posted on Oct 09, 2010
How do I exit the video 6 component 1mode and return to tv mode?
With remote go into the menu. Under video you should find a source selection. Hit that and toggle to the TV source and hit ok. Now you may have a button on the TV that says source or input. If you do, hit that until you get TV to come up. CRT tvs did not make this process easy but your remote may also have an input or source choice for you that you can hit until you get to the TV. Also called display sometimes.
Feb 06, 2016 | Televison & Video
I plugged my xbox 360 SLIM into a 220v using a 110v power brick and it blew up is the xbox ok?
Possibly. There is no way to tel until you replace the power adapter and connect it to an appropriate power source.
Oct 11, 2014 | Microsoft Xbox 360 Console
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
My xbox 360's wires are all plugged in the correct places and other people can see my xbox profile when i turn my xbox on but on my component source on my tv it says no signal so i can not get a...
If you have the AV cable that has the switch on the Xbox end, make sure that it's in the correct setting. Your cable could have shorted out if this does not work.
Aug 17, 2011 | Microsoft Xbox 360 Console
I have an Ilo 26"
try adding another source to rule out tv issues then after that try looking up how to reset the xbox's video output i know my playstation can do it so xbox must have a defaulting setting obviosly whoever fixed your xbox left it in 1080p and your tv is 1080i minor problem just mildly frustrating ok hope this helps
Nov 17, 2010 | iLO 3200 32 in. LCD Television
"NOT SUPPORTED MODE" when using my xbox 360
If you got that while playing it sounds like its your GPU melting... when the older xbox360s get hot the circuit starts to warp and sag in the middle.. the causes the GPU to seperate from the board which gives you wierd or no graphics... ppl suggest "the towel trick" wrapping you xbox in a towel to overheat it in hopes it will reconnect the GPU.. otherwise there is very little you can do.. just hope MS will repair it for you or buy a new one.. i have the same problem at the moment with my friends old one.. so im currently working on a solution.. will try and let you guys know if i find something that works...
May 13, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Cannot program intec xbox360 remote: 1. Do not have program codes for Philips Projector Flat screen. 2. Do not know how to use scan programming. If anyone knows one or the other I would appreciate the...
Put TV/Projector on Standby mode
Press and Hold the "OK" & "TV" Buttons for three seconds until the pad illuminates 3 times.
Press the channel up button repeatedly, until your TV turns on.
Press and hold OK
Pad should flash.
Mar 28, 2009 | Intec Wireless Remote Control For Xbox 360
Xbox component output causes "epileptic" flickering
x box 1 on a hdtv r u sure , or do u mean the 360?
Sep 13, 2007 | Microsoft Xbox Console
TV makes high pitched noise
In 1080i the horizontal frequency more than doubles from 480i. This means that possibly the high voltage transformer or a linearity coil is occilating at that lower frequency.
Jan 26, 2007 | Samsung TXN3271HF 32" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
