Question about Hitachi Video Cameras
Cam Corder disk access
Cannot access disc after completing instruction to Repair Data. Instruction is to Replace Disc or Re format disc. This will destroy Data?
How to repair disc or transfer data to Mac Computer?
    Genius:
  • 1,665 Answers
Format hard drive
Hi
To "format C" means to format the the C drive, or the primary partition that Windows or your other operating system is installed on. When you format C, you erase the operating system and other information on the C drive.
However, it's not a straightforward process to format C. You can't format the C drive like you can format another drive in Windows because you're within Windows when you perform the format. To format C from within Windows would be like lifting a chair in the air while sitting on it - you can't do it.
The solution is to format C from outside of Windows, meaning you need a way to format a drive from somewhere other than your Windows installation. The easiest way to do this is to boot to an operating system (with formatting abilities) from a CD/DVD/BD drive, flash drive, or floppy drive.
This might all sound very complicated but it's actually quite easy to format C. Below are 5 completely free ways to format your C drive:
Note: If you're trying to format your C drive because you want to replace or reinstall Windows, you do not need to format C ahead of time. Formatting is done automatically during the Windows installation. Skip this article entirely and instead see How To Clean Install Windows.
Important: Formatting your C drive does not permanently erase the data on the drive. If you want to completely erase the information on the C drive, see Option 5 below, Wipe the Drive Clean With Data Destruction Software.
1. Format C From a Windows Setup Disc
The easiest way to format C is by completing part of a Windows installation. It's not easiest as far as number of steps goes, but since most of us have a Windows Setup DVD lying around, we have easy access to a means to format drives outside of Windows.
Important: You can only format C this way using a Windows 7 Setup disc or a Windows Vista Setup disc.
However, it doesn't at all matter what Windows operating system is on your C drive, including Windows XP. The only requirement is the disc you use to format C - either a Windows 7 or a Windows Vista Setup DVD. Feel free to borrow a friend's disc if you'd like to try this method but you only have Windows XP... or some other operating system.
2. Format C From a System Repair Disc
If you don't have access to a Windows Setup DVD, but you do still have access to a working copy of Windows 7, you can create a System Repair Disc and then boot to that disc and format C from there.
You can only format C using a System Repair Disc if you have access to Windows 7 to create the System Repair Disc. If you don't have access to Windows 7, find someone who does and create the repair disc from their computer.
Note: A System Repair Disc created from Windows 7 can format a C drive that has any Windows operating system on it, including Windows XP or Windows Vista.
3. Format C From Recovery Console
If you have a Windows XP Setup CD, you can format C from the Recovery Console.
The biggest caveat here is that you must also have Windows XP installed on your C drive. However, if you don't have access to Windows 7 or Windows Vista, this option may be your best to format C.
This Recovery Console method to format C also applies to Windows 2000. Recovery Console does not exist in Windows Vista or later, nor does it exist in Windows ME, Windows 98, or earlier.
Dec 14, 2011 | Samsung R580JBB2 Notebook
I habe Toshiba Satellite PSAB6E-00X00PG3 PC Notebook, When I on it IS NOT DETECTING HARD DISC, Please guide what i can do to solve this problem
Try booting off another disc like an install disc. When it asks if you want to repair the OS say yes. It should take you to a recovery console. Run disk diagnostics (chkdsk c:) and see if it can find the disk. If it can't and there is data you need to recover from the disk, take it to a repair shop or a computer technician for troubleshooting. If you do not need any data off the disk, then you could try formatting the disk but EVERYTHING on the disk will be lost so do not attempt a format unless you are sure you do not need any data off the disk.
Jul 04, 2011 | Computers & Internet
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
I have got a 2gb scan disk memory card i cant access it or format
Hello Friend,
Here is a method to try:
  1. Backup all data from your hard drive to another hard drive or CDs or DVDs.
  2. Turn off your computer.
  3. Insert the USB drive to a USB port.
  4. Turn on your computer.
  5. Hit the F8 key when prompted to get to your system bios. Some computers required the Delete key or F2 instead of F8. There should be a note on the screen that specifies the key.
  6. Navigate your bios (usually using your cursor keys) to boot from CD drive first. Save and exit.
  7. Insert your operating system disc aka Operating System Restore disc. Your computer should restart. If not, restart it yourself.
  8. Follow the instructions for installing your operating system. When the option to select which drives to format comes, you should be able to see your USB disk in the list.
  9. Format the disk with FAT32 for Win98 or previous. Format with NTFS for anything after e.g. NT, 2000, XP etc.
  10. Depending on your options, you may be able to opt out of the operating system install at this point. If it was running well beforehand and you can, leave your other drives alone and quit the re-installation.
  11. Reset the computer to boot from the disc drive the operating system is on instead of the CD drive as before. You should have your working flash drive detecting and usable now in windows.
  12. If you didn't get the option to opt out of the re-installation, continue to follow the instructions onscreen and complete the re-installation, formatting whatever drives are required. Note: Do not try to install your operating system onto your USB disk drive. Also be cautious when formatting to keep in mind all data could be lost.
Best Regards,
Oct 29, 2009 | Electronics - Others
Hard Disk failure
Try to run CHKDSK from command prompt, and if that doesnt work, its probably corrupt / hard to recover
Apr 21, 2009 | Dell Dimension 2400 PC Desktop
Disc formats do not work on my vista computer
You need to download a media converter to do this!
Dec 11, 2008 | Panasonic VDR-D220 Camcorder
Disc error
if you get a disc error, DO NOT TRY TO REPAIR the data.
When you get a disc error, turn the camera off, turn the camera back on. When prompted to repair the data, select NO.
The camera should prompt you to Format the disk, select no.
you should go back to a normal camera screen, at this point push the FINALIZE button on the outside of the camera to finalize the disc.
This is your only option to save the data.
Never try to repair the bad data, it never works.
I have done this on two occasions, and it worked both times.
Dec 02, 2007 | Hitachi DZ-GX3200A DVD Camcorder
Video Cameras Logo
306 people viewed this question
Top Hitachi Video Cameras Experts
jamie suver
Level 1 Expert
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
