Question about Acer Aspire 5100 Notebook
DVD drive malfunctioning
My dvd drive is malfunctioning after I played a low quality dvd. How do I troublshoot this error?
  • Salatiel Jun 03, 2008
    I am abit reluctant to use the firmware as it may damage my hardware. I'll try some other options first then try firmware. Are there any other solutions?
  • Salatiel Jun 05, 2008
    thanks I will try using alcohol first. What about using those lens cleaners used for normal cd drives?
  • 3 Answers
Try to do firmware update to your dvd.Find out the model than search on the internet.
Posted on May 30, 2008
  • Bogdy88 Jun 03, 2008
    try to clean the lens of your dvd with alcohol .
My DVD player only plays dvd disk cannot play cds what is the reason for this problem
> what is the reason?
Malfunctioning hardware inside the DVD/CD drive. Spend $35 to replace it with a new CD/DVD reader/writer.
May 22, 2011 | Computers & Internet
My panasonic dvd player is displaying error u11 code wont play any dvd's
If you are trying to run a recorded DVD (saved a video or movie on to it), it could be the quality of the disc. I would recommend buying quality DVD's, the lower quality ones can create read errors (U11).
Jan 25, 2011 | Panasonic Televison & Video
Error code 0107 pops up when I try playing any DVD
it may be the error of your low quality cd or some missing files during the copy rides on your cd change your cd and use dvd of cyberlink it can help you
Jun 02, 2010 | CyberLink Power DVD DX 8.0 for PC
DVD plays in DVD player is not seen at all by Windows XP
Hi,it's obvious from your problem that the particular disc that cannot be viewed on your computer is of a formatt not supported by the windows XP.some DVDs are of low quality which can be viewed practically on any DVD player but as a result of their low quality and the sensitivity of the Windows they are not recognized by your computer. In as much as other DVDS play on your computer,it means there's no problem with your computer,but an unsupported disc formatt is been trying to be viewed and there's nothing you can do to view a DVD formatt not supported by your computer.please don't be bothered.
Thanks and take care
Apr 21, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
Xbox360 can't play dvd game only dvd movie or cd
this is a common problem faced in xbox360..you have to use original DVD else the low quality DVD leads to damage your xbox360 lens...for further reference click here for repair guide....
Sep 04, 2009 | Microsoft Xbox 360 Console
Cd/dvd rom
I am presuming that you have the correct driver for the DVD, and nothing else has changed (no new DVD software that might cause this problem by addressing the drive improperly). Nero and Power DVD can both cause problems if your DVD is newer than the software version.
Now, all that out of the way, here is the diagnosis. DVDs are much higher density than regular CDRoms. DVDs average 4.5 gb, whereas a CD is caped at 0.7gb (700mb). Thus, DVD drives have very low tolerance for ANY kind of error. Therefore, DVD combo drives are not likely to last as long as the rest of the laptop's hardware. Shock at relatively minor levels can damage a DVD drive. Often, they will still open a regualr CD, but fail to read a DVD directory. Your error code, if it is posted at startup, indicates the drive is malfunctioning. You can test it easily. Usually there is only one screw that holds it in (underneath the laptop, about 4 inches from DVD tray cover, towards the center). Turn off laptop, flip it over on a towel, and remove that screw. Tuurn the laptop over again, then insert a straigtened paper clip into the small hole in the DVD tray face. Be careful to push lightly and STRAIGHT in with this paper clip and the tray will pop open. Pull gently, and the whole DVD body will slide out. With a new or used replacement DVD or CD, reattach any hardware on your old DVD to the new one, then slide it back into the laptop 9no need to install screw just yet) Start laptop. If error is gone and DVD plays OK, insert the screw again and make your old tray cover fit the new drive (always can be done if you look closely to find the tabs and remove it gently). Sometimes some plastic will need to be trimmed with an eExacto knife to get a good fit.
Feb 16, 2008 | Toshiba Satellite A60 Notebook
Jamo DMR60- sound doesn't match dvd
I have the same problem. I have been in contact with Jamo Denmakr and Norway. They are aware of the problem. There are two issues/answers:
1 If the DVD your're playing has scratches reading error accumulate and then audio sync problems occur. (My meaning is lo quality DVD drive). You might overcome this by reburning the divx file to a new disc to avoid read errors.
2 The DVD drive itself is defective and should be replaced. Warranty should cover this of course. I do receive my DMR-61 this week after DVD drive change. I hope this will fix it...but I don't believe so. Crossing my fingers.
Henning
Jan 02, 2008 | Jamo DMR 60 DVD Player/Receiver
Yamaha DVD S520
yes sir, starting to malfunction and needs replacement now. unless you cant ry cleaning it manually maybe it will help a little but sooner or later it will again give you same trouble
Aug 03, 2007 | Yamaha DVD-S520 DVD Player
Showing "Disc Error" While playing DVD's
the disc tray is not leveled properly, i had the same problem too and samsung repair centre just adjusted the tray.
Apr 29, 2007 | Samsung HT-DS100 System
When should I use a DVD-R / DVD-RAM / DVD-RW?
Write Once – After finalizing, a DVD-R disc can be played back in approx. 95% of home DVD players and PC DVD drives Capacity – 30-60 minutes (depending on the selected filming mode) of high quality motion video can be stored on a single of a disc. Re-writeable – DVD-RAM allows for recording and re-recording of movies and still photos up to 100,000 times per disc. DVD-RAM is like a removable hard drive. Compatibility for video playback of DVD-RAM in standard home DVD players is fairly low. DVD-RW cannot store true .jpeg digital still photo’s like DVD-RAM, however it is re-writable and has 80% compatibility with home DVD players.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Acer Aspire 5100 Notebook Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
