Question about Samsung Washing Machines
I can not seem to balace the washer- it dances around the room on spin. front loader j1045 6mths old
  • 46 Answers
Has anything changed? have you moved it? is it level? Check the level of it and if it is infact NOT level make it so.. If it IS level I would not play with it.. get a warranty repair tech out..
Hope this helps
Posted on May 30, 2008
SOURCE:
Machine dances around room on spin. Floor is level and concrete
Is it making a loud thump? If so, it may be the basket drive. If not, the suspension to the washer may be damaged.
Mar 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The washer is 2.5 years old. The Basket has no stability during the spin and wash cycle. The basket bangs against the side of the machine and the machine bounces around the laundry room moving sometimes...
they do dance well dont they? this is caused by the support springs coming off the drum holder and the drum will have droped a little as well,
take off the top of the washer and look down each side you should see the support springs if the off just hook them back on or fit new one's?
dont leave this as it will pull all the pipes off inside the washer
its an easy fix,
Aug 09, 2010 | GE Energy Star WCVH6260F Front Load Washer
Washer banging during spin cycle. Seems to be off balance. sm 8525079
there are balacing feet on the underside of the washer on each front corner.....they turn like a screw.....
Nov 16, 2009 | Washing Machines
GE Washing machine model WCSE 416OB is making a loud noise when spinning and not fully wringing the water out of the clothes--what could be the problem?
I fyou have a well balaced load and it is not banging side to side or doing the wash machine dance then it is probably the trasnmission or coupler. IF you want to spend some money or lots of money to have it replaced it's up to you it wouldnt hurt to have a authorized techichian take a look at it. If it is and it is nt worth fixing then take a look at a front loader wash machine you cant go wrong with one of those as it gets more water out of your clothes which means less time int the drier and saves you allot of money.
Cheers
Al
Sep 11, 2009 | GE WBSR3140DW Top Load Washer
MY SON LOADED A LARGE AMOUNT OF CLOTH INTO THE WASHER AND WHEN THE SPIN CYCLE CAME ON THE WASHER STARTED MAKING A HORRIBLE BANGING NOISE. it does not look like the springs are broken but the washer seems...
I'm suprised the unit was not able to spread a large load around to balance the drum. Maybe some item bunched up and made one side heavy. For a front loader, a proper load is just about all you can cram in there dry. You'll notice when the clothes get wet, they take less space, and when they are spun, there should be lots of room in the middle.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
Frigidare Model # FTF2140FS1 problems with spin cycle
not a very sturdy pedestal, front loaders need concret solid base
Mar 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Dancing washing machine
Check that the washer is level , and that there is no movement on it.
Make sure you have not overloaded it.
An out of balance load could cause problem , especially if you had something heavy or extra large in it..
A loose concrete balance weight., or suspension spring unhooked or broken..
Not draining properly ,check filter if there is one usually at front behind removable cover at bottom.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Indesit WA 125 Front Load Washer
if its real new as in you just installed it look behind hte unit for shipping braces that haven been removed.. they keep the machine solid in shipping and reek havok if not uninstalled
Mar 17, 2008 | Whirlpool AWM6100 Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
130 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
