How to install eznet p/n:243127-421 rev :01a in ASUS a7m266?
Falcon2 rev 1.05g diver for windowsxp install
Log onto the Asus website to see if you can get it there.
Dec 27, 2013 | ASUS Falcon2 Rev:1.05G TV Input
Network interface card was working fine. it just quit working and i have no lights on it now. i have already tryed a brand new card and still have the same problem.
Have you checked the ethernet cable (both sides)? If there is a cut, the lights are not active. Either try this cable at another pc, or try another cable at this pc.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 30, 2010 | ASUS AMD 761 Chipset A7M266...
No backlight. I'm looking for a schematic for the acer al1916w with power/inverter board dac-19m0005 rev: 01a bf.
<p>How about the whole <A href = "http://www.go-gddq.com/upload/2009_06/09060313346662.pdf">Service Manual</a> ?</p?
Jun 14, 2009 | Acer AL1916W 19" LCD Monitor
Lost my motherboard CD
you can download your driver from here.
Select Product - Motherboard
Select Series - Socket A(462)
Select Model - A7M266-D
Click Search and a Page will come up asking Select OS.
http://support.asus.com/download/download.aspx?SLanguage=en-us
May 12, 2009 | ASUS AMD 760 MP Chipset A7M266-D...
I want the asus P5PE-VM series intel 865GChipset support CD rev.239.02
Asus P5PE-VM series intel 865GChipset support CD rev.239.02 ethernet controller Driver
May 11, 2009 | Computers & Internet
Boot Failure
Try another stick of memory, I know that sounds funny, but I beat my head trying to figure the same issue out one day... and that was the issue....
Hope this helps, if so please rate my solution accrodingly. Thanks, David
Mar 19, 2009 | ASUS A7M266-D (A7M266-D/LAN) Motherboard
My d drive CD-DVD ROM,has gone problem again with 3 others
First of all, here is a link to download the ASUS A7M266-D manual in PDF format:)
http://www.unitycorp.co.jp/support/download/manual/a/a7m266_d_e.pdf
The CD/DVD must appear in the BIOS before it will be seen and used by Windows. There are two reasons it (they) might not be seen. There is a jumper pin block on the back of each CD/DVD to designate Master, Slave or Cable Select. you must move the little plastic jumper clip to the correct position. If you are using a 40pin IDE cable, the top drive should be Master and the bottom drive should be Slave. If you are using the newer, smoother 80pin cable then both should be set to Cable Select. Having the jumper in the wrong position will prevent the IDE controller from sensing one or both of the drives as the signal will get confused in the cable.
Next you have to change a BIOS setting to inform the system that you now have a new device on that channel (unused channels are usually defaulted into the NONE or AUTO position so you do not get a device missing error message on startup). This is where the manual comes in. The specific instructions for the Award BIOS in you system are found on page 48 of the manual.
If you are just replacing the original CD/DVD, it should be in the Secondary Master channel. If you are adding a second drive then your new CD/DVD will be in the Secondary Slave channel, which you should change from NONE to AUTO. You will have to reboot for the change to take effect. Go straight back into the BIOS to verify that the added drive is recognized (the BIOS should list the drive type and information). Once you can see it on the BIOS screen, Windows will recognize and automatically configure it.
Now, as for your Windows saying the drivers are corrupt, that is a different problem which usually happens after removing software to burn CDs/DVDs. It is not an uncommon problem. I believe a link that describes your problem and solution is here:)
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Finally, you mention XP Professional like you are going to reinstall your hard drive. It may not be necessary unless you are doing it "just because". If you have/had XP Home on the hard drive, you will have to do a full installation for Professional, you will lose all data and programs, AND you will need to locate the correct drivers for your system to get all the pieces to work. You will also need an XP Professional COA to activate the new operating system, as you cannot activate Professional with a Home edition key.
For most users, there is no advantage in using Professional over Home edition (there are some new features used for networking, remote desktop, etc. that single machine home users just do not have reason to use). If you are installing Pro just to fix your DVD problem, it is probably unnecessary.
Please comment with your results.
Jan 04, 2009 | ASUS AMD 760 MP Chipset A7M266-D...
Can't boot bios
This is common after doing a BIOS upgrade. It usually means that the bios was successful, but that the motherboard is just now recognizing that it has a new bios. In other words, it's seeing that the new bios is not the same as the old one you had before, and is giving you a warning that it's changed. You can usually go into the bios, and clear all messages. This should make it go away.
Post your specific motherboard, and i'll see if I can get you more info.
Steven
Sep 16, 2008 | ASUS AMD 760 MP Chipset A7M266-D...
Asus a7m266 was watching somthing on a tv tuner and computer died, every time i switch on all i get is a repeditive 1 second long beep, then 1 second pause no bios or display
try taking out the battery on *********** board, then put it back in and try it. this should reset your bios.
also there should be a 2 prong jump block on *********** board to reset bios.
check *********** boards book for location of this pin.you will need a jumper to do this. if you have any old hd's or cd dvd drives laying around you can use one of them. the little black thing for master/slave jumping..or an old mother board.
i have like 4 of them in the bottom of my case just incase i have to reset bios the hard way.
hope this helps.
willowcreekjim
Aug 27, 2008 | ASUS Computers & Internet
Windows Instalation
change the windows version
or change the ram
Nov 08, 2007 | ASUS AMD 760 MP Chipset A7M266-D...
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
