Question about HP Pavilion dv1000 Notebook
Re:My laptop turns on and then it turns right off!!!...
Is there any way I can fix it myself rather than bringing it in a shop. Or a cheap way to fix it like buying a new cpu fan or some heating compound? Please advise....
  • 1 more comment
  • nightwalker1 Jun 22, 2008
    when i turn my computer on it works fine for a couple of min but then it shuts down... i have the Operating System CD and the Application and Driver Recovery DVD and i've tried everything with both but when everything is loading it shuts down and it also shuts down when i try to do a scan for viruses or spyware...... What can i do?????
  • francisco de mesa
    francisco de mesa May 11, 2010
    can you please give more details about your issue?
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    well..perhaps you'll elaborate, in the notes, what you are actually experiencing?
Dv1000's have a known issue with the heat sink fan. the ball bearing in the fan (which is what allows the blades on the fan to spin) will "pop" out making it so the fan is not able to spin.
good news is its incredibly easy to fix. unfortunetly to get to it you will need to completely disassemble the computer to get to the heat sink fan.
once youre there all you need to do is squeeze the middle of the fan from both sides. you should hear or feel a little pop or click.
reassemble and enjoy.
Posted on Jun 25, 2008
Wont turn on
I had a co-worker bring me his Asus A55a laptop that would not power on. The problem turned out to be the small power control board right under the power button. The parts was only $15.00 plus shipping. The local geek shop wanted $180.00 ( 3 weeks turn around time).
Aug 05, 2014 | ASUS VivoBook S550CA-DS51T 15.6"""
Toshiba Laptop L655dS5050 will not boot unless I wrap in a towel to heat up
That is a bad situation to be in out of warranty; There is no easy quick or cheap fix for this; This would be something for a Local PC Shop to fix unless you are savvy enough, and have the precision hand of a surgeon. You can conceivably fix it yourself.
Long story short; You are correct; My first guess is a broken solder point somewhere on the motherboard or Power Supply;
Power Supplies are a cheap fix, but if you do not find the problem in the Power Supply you will have to replace the motherboard.
Most local PC shops will suggest buying a new laptop because the cost of repair if it's the motherboard is nearly equal to a new laptop.
Troubleshooting:
Find an alternative source of power to test the laptop in other words eliminate the AC Adapter and battery from the equation; Test using a different AC Adapter only, see if the Laptop boots up; If it does, it's more than likely either a bad battery or bad AC Power Adapter.
It's a shot in the dark but the Power Jack may be loose and when power is applied to it the heat buildup may secure the connection to the motherboard which allows you to boot. (Although this would be a first time explanation regarding this) Usually power jack issues are intermittent start ups. Replacing of the power jack; cheap, you can buy the part yourself; again if you are good with soldering you can fix it yourself as well; You will have to disassemble the laptop completely to do this. This repair is expensive at a local PC shop in excess of $100-200 or more.
A motherboard replacement can cost in excess of $300 or more at a local PC shop.
Hope this helps or at least guides you in the right direction.
Sep 26, 2013 | Toshiba Satellite L305-S5921 Notebook
Computer does not want to turn on and turns right off
Your motherboard is damaged, or the device that controls the electrical current is damage.
You can either fix it yourself, or bring it to a shop for repair.
If you choose to fix it yourself, you can order the parts on eBay, and find a guide on taking it apart on Google or Youtube.
I apologize :(
I hope this helps :)
It's also possibly that your battery or charger is at fault :o
Feb 24, 2013 | Samsung Computers & Internet
Startercord broken
IF YOU TAKE OFF THE STARTER AND BRING IT TO YOUR LOCAL SMALL ENGINE REPAIR SHOP I THINK YOU WILL FIND IT IS A CHEAP FIX, DOING THIS JOB (REWINDING OR LOADING) IS JUST A LITTLE BIT TRICKY AND HAVING A PRO DO IT SHOULD COST ABOUT 20 BUCKS. IT'S ABOUT TAKING IT OFF THE MOTOR WHAT SAVES YOU THE MONEY = COOL CHEAP FIX .. JAY THE POOL PUMP GUY IN LONGWOOD FL
Feb 02, 2012 | Toro Garden
I have an acer travelmate 2410 laptop and when i turn it on it works everything turns on but my screen remains black. i cant even log itnto my user account because it doesnt even bring it up. it just stays...
On my laptop there is a small button near the hinge end that switches the display off when the top is closed. Make sure yours is coming up. It is something you can check easily.
Nov 29, 2010 | Acer TravelMate 2300 Notebook
A scratch on the rare side panel of lexus rx
Unless you are good with a bunch of body tools, you don't want to fix it yourself. I wouldn't take it to the dealer, there are plenty of body shops around that can fix it. But most will tell you it is not worth fixing. You might hang around the body shop at the dealer and make friends with the guy, He has all the paints right there, then drop the question on him. How much to fix this scratch?
I'm afraid that a rattle can just doesn't do it. Hope this helps.
Apr 14, 2010 | 2000 Lexus RX 300
AUDIO OUT JACK MALFUNCTION
Buy this instead: http://www.dealextreme.com/details.dx/sku.22475
The usb-soundcard works right out of the box, no need to search for drivers. 2.26 $ incl. shipping. cheap and works good.
Sep 08, 2009 | Compaq Presario 700 470024-192 Notebook
My is300 is out of timing i need the diagram to fix it
Thanks for using FixYa!
You need a special tool to fix timing problems. You'll need a timing gun. Most cheap garage shop has this tool. Just bring your car to a cheap shop and have your car properly timed. This is only a 15 minute job. I hope this helps.
Have a nice day.
- HotRatchet
Aug 01, 2009 | 2004 Lexus IS 300
Acer 5930 dead graphic card can it be fixed? or is it fixed to motherboard
Most laptops graphic cards are built right to motherboard. You can probably bring it to computer repair shop and they can solder new capacitors on it. But they don't make them seperate where a person could swap it out.
Jun 03, 2009 | Acer Aspire 5920-6574 Notebook
HP Pavilion dv1000 Notebook Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
