Question about Sony Televison & Video
When I turn on my Sony Trinitron (@ 2001) there is a loud honking sound that happens and its very annoying and my neighbors bedroom is right next to the TV. How can I stop it from doing this. I have the headphone jack in front hooked up to a wireless headphone attachment, but it was doing this noise when I had a regular headset hooked up to it..... and it does this noise when I don't have the headset jack in use. I turn it on and almost immediately it puts out this "HOOOONK". I know its from the thing starting to warm up, but I'd like to figure out how to eliminate this annoying noise. Sometimes for a period it will stop the noise, but I can't figure out what's different (setting, or connections, etc.)....... HELP!!
  • 998 Answers
You have the problem in the pre amp you should check it if its grounded or clean it first
Posted on Oct 09, 2010
Dodge stratus grinding noise in front ???
your rotors are wet they have to dry out
Nov 26, 2013 | Cars & Trucks
My stero is not loud enough.
Check for the tape monitor being on or amp mute type function. Larry's Electronics
Apr 27, 2010 | Audio Players & Recorders
I have the Sony XBR 40in Trinitron and it won't
sounds like you have some cold solder or bad joints,power section, inspect it ,with the back off, but be carefull.........i had one that did that...bad connection in solder joint...had to resolder,if you have to resolder,make sure it is unpluged.hope this helped....
Feb 23, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
What is loud sound suppressoion
It is a dynamic range compression feature. Due to the widespread abuse of Dolby and other digital dynamic range features, normal listening levels may be interrupted by VERY LOUD explosions, etc. which may not only wake you up, if you fall asleep in front of the set but can make your neighbors very annoyed. To counteract this, a loud sound suppression feature, sometimes called "Late night listening" is offered to limit the loudest sound you will hear.
Jan 09, 2010 | Sanyo DP42848 LCD TV
TV keeps changing channels by itself
check that another object is not turning on and off when this happens A/C an oven etc. Even the kid next door shooting your code out his bedroom window. Great trick i did on my neighbors!
Please rate our help
Sep 25, 2009 | GE 31GT660 TV
Sony Trinitron KV-32FS13 Popping sound
Loose connections!! (ground areas).ANd audios section!
May 12, 2008 | Televison & Video
32 sony wega
Shorted diod d503 next to HOT. If you are not a tech probebly best to take it to the shop.
Apr 16, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega KV-27FS100 RANDOMLY Turns itself ON
You said around 4pm TV is switched on everyday. Check in menu options any on-timer and off-timer is changed. If it is not there is a problem in microprocessor section. EEPROM ic malfunction also shows these type of symptoms. But it can be done by Technical persons only. This is not a major problem. This is due to surge current and lightening like that.
Sep 06, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
