Question about Harman Kardon AVR 130 Receiver
When i play AVR 133, after few seconds no sound, but power is ON. If switch off and on again, same problem no sound after few seconds. please can you help me
Have you got AVR 133 manual plz send soft copy to mrutkarsh@gmail.com i'll definately help you.
Posted on Jan 30, 2011
Switches off after five seconds.AVR-590
There are a few things that could be causing this to happen. The first thing you should do is check all the speaker wires connected to see if they might be touching each other somewhere. What you are describing sounds like there might be a short. Also, is the receiver well ventilated? What is happening is that it is protecting itself but shutting off.The 590 is going in to Protection Mode due to some fault it perceives. The quick flashing red power light (as opposed to a slower flashing light) would indicate either speaker wires touching another terminal, driving 4 ohm speakers to loud, or amp failure.
Jan 18, 2016 | Denon Audio Players & Recorders
P 133 manual
Do not check dolby digital + option.
Dec 15, 2013 | Harman Kardon Audio Players & Recorders
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
Sound and video goes out periodically for a a couple of seconds every few minutes. Power stays on, all sound and video stops.
I am assuming you are connected HDMI?
This is a common problem when connected with HDMI. HDMI checks for HDCP codes every three seconds and if it doesnt get the proper response from the devices or repeater (amp) it will drop the connection and ask again in 3 seconds. If it receives the proper key it will display the signal again.
Have you tried the firmware update? http://www.usa.denon.com/AVR-4308CIFirmwareUpdate-Web1128.pdf
I hate to say this but HDMI is not perfect yet so there may not be a solution to this except to drop your inputs and outputs to component video and digital audio. The only source that will be effected from a resolution stand point is a BluRay which can only display 720p or 1080i (not 1080p) when ran through component video.
Nov 08, 2009 | Denon AVR-4308CI Receiver
My Harman/Kardon AVR 140 is stuck on stand by mode
I have the same problem on my AVR 1550 - its been bugging me for ages then it works again, then it doesn't ...
Aug 28, 2009 | Harman Kardon AVR 140 Receiver
Denon AVR-2309C1 will not play sound through
Turn off zone 2 then turn your receiver on the main zone on Radio, tune in a station and check for audio. Post a comment and let me know if audio works that way. If you don't have any audio, list your other equipment makes and models as well as how they are interconnected to your receiver (cable type) and I will help you troubleshoot
Jun 28, 2009 | Denon AVR588 Receiver
Denon AVR-1508 Receiver problems - cuts off and goes into protect mode
Usually when the unit runs for a while before shutting down there are two possibilities:
1) There is a small amount of DC current present that effectively heats up the speaker coils enough to cause a temporary short circuit that kicks in the protect circuit.
2) The output transistors or bias transistors are sensitive to heat and breaking down again causing the protect circuit to kick in.
A few experiments to try:
1) Does the time to shutdown change depending upon the volume level?
2) Is there any background noise coming from the speakers? Listen to a blank tape for example. Is there a hum or any other noise that you would not normally expect?
3) If you have a DC voltmeter, check for any voltage between the speaker lines.
Update this and we'll try to narrow this down.
Dan
Aug 18, 2008 | Audio Players & Recorders
Dead
IT COULD BE A FUSE , needs to be replace , if your handy , you can do it yourself , open unit , and check where the power supply is .look for a tiny glass tube type fuse , replace , and try again , hope this helps , please rate , AJ
May 07, 2008 | Harman Kardon AVR 7200 Receiver
Denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Mar 06, 2008 | Denon AVR-2106 Receiver
Harman Kardon AVR 130 Receiver Logo
301 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
