Question about LG Washing Machines
NEED TO REMOVE CLUTCH ASSEMBLY ON LG FUZZY LOGIC TO REPLACE BUSHES
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
SOURCE: LG Fuzzy Logic WF-T7030TP Turbodrum Sensor
Error Peurta
Posted on Mar 24, 2008
  • 155 Answers
SOURCE: LG washing machine fuzzy logic 8.5 kg not agitating
The reason to this problem can be due to any one
of these reasons.
Lid Switch
Motor Coupler
Belts
Clutch
Drive Motor
Drive Pulleys
Transmission
Agitator
Posted on Sep 06, 2009
supertech6
  • 513 Answers
SOURCE: i have an LG fuzzy logic top loader, black pieces
This is probably the seal around the door and drum. Professional work is required.
Posted on Mar 20, 2010
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Apr 17, 2016 | LG WM Washing Machines
Have a LG fuzzy logic 8.2kg wf -8071ttp it gives a de error
DE usually means door open,can also mean that door lock not working
Dec 20, 2015 | LG Washing Machines
DE error massage on lg fuzzy logic 8.2 kg 8071TTP
The dE error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Jun 22, 2015 | LG Washing Machines
How do i fix an LG 5.0 fuzzy logic washer that keepscoming up with a DE error?
The DE error indicates a Door Error condition....check out the door for any distortion or misalignment with the door latch.
Check the door latch assembly for continuity and if faulty replace the switch.
Mar 24, 2015 | LG Washing Machines
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
of these reasons.
Lid Switch
Motor Coupler
Belts
Clutch
Drive Motor
Drive Pulleys
Transmission
Agitator
Sep 06, 2009 | LG WFT1071TP Top Load Washer
I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
Aug 07, 2009 | Washing Machines
LG FUZZY LOGIC
Are you sure it is the bowl and not inside the pump with the impellar hitting it on spin cycle? I just had the same problem and had to remove a dime from inside the pump.
Sep 22, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
237 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
