I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
    Problem Solver:
  • 3 Answers
Put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
Posted on May 30, 2008
    New Friend:
Nothing from the inside, i really need help,
Posted on Jun 22, 2013
I have a coleman evcon ac furnace. the unit inside works and the outside won't
Posted on Jun 17, 2008
2 Suggested Answers
  • 146 Answers
SOURCE: My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
Posted on May 28, 2010
Coleman evcon furnace
So the furnace will come on and heat sometimes ? Then other times it will click but not heat ?
Check for fault codes if it has them and make sure it is clean inside burner tubes and clean the flame sensor.
Oct 13, 2013 | Heating & Cooling
Coleman electric furnace
You don't say whether you replaced the blower but that could be the next thing to check
Jul 23, 2013 | Heating & Cooling
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Sometimes the fan inside comes on but outside unit isn't running
Its likely a computer generated time delay so the refrigerant can equalize pressure. Its a safety working properly.if people are fighting over the temp, and it shuts off and someone turns it down to soon, the result you described is normal, even essential.
Jul 15, 2012 | Coleman York Evcon Furnace Control Circuit...
Does your furnace have an adjustable fan limit switch it has to be adjusted. If it has a timer check if it can be adjusted.
May 28, 2010 | Coleman Heating & Cooling
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
Heating & Cooling Logo
644 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
