Question about Canon PIXMA MP780 All-In-One InkJet Printer
Service error 5C00? what's that?
  • can't find where to fix this error. can anybody help?
  • debbiez163 Jan 15, 2009
    When I try to print, a pop up screen comes up and tells me there is a "Service Error 5C00", "cancel printing", "hit ok on printer"... this does nothing....the printer light doesn't even stop flashing.
  • 43 Answers
Service error 5C00 is a purge unit error. The purge unit like a spitoon to the printhead where is stops. There is a sensor in the purge unit; when it is blocked (usually by ink build up), that error is given. The error indicates that the purge unit may be full or at least gunked up. It may be possible to clean the purge unit and sensor to make the error go away. I base this on information learned with experience on another Canon product (Model i560). Hope this helps...
Posted on May 30, 2008
  • zlatyshev
    zlatyshev Dec 23, 2012
    Could you attach photo please where this sensor is? please answer zlatyshev@mail.ru
SOURCE: canon pixma ip90 printer
if your printer is flashing 4 orange and then back to green repeatedly - i found a solution to it for my ip90v - i opened the printer and checked the right hand side cogs - carefully turn them and you may see that some stray paper jam debris is blocking the cleaning unit from returning to its home in the bottom front of the printer - carefully remove it and replace the casing - turn on and with any luck you will have a dully functioning ip90 like i did.
Hope it helps some others out
Posted on Dec 13, 2008
jeffdynamics
  • 18 Answers
SOURCE: Service error 5C00 or 5100
5100 Make sure nothing is blocking the cartridge movement, if not requires service.
Posted on Apr 16, 2008
celibytes
  • 70 Answers
SOURCE: canon printer ix4000 service error 5C00
Focus on the purge unit,remove it from the printer and better check the two gears left and the sensor.
Posted on Aug 25, 2009
cene765
  • 787 Answers
SOURCE: canon ip3000 shows service error 5c00
5C00 is Purge unit error.Check for object around the purge unit.
Posted on Oct 15, 2009
PCTechOnline
  • 532 Answers
SOURCE: I get Service error 5C00 for my Cannon i80
Canon USA has a down loadable file for the manual.
Here is the link.
Here is what is being said of this error on the forums:
Fixing this error is much easier as it looks. Unplug the printer completely. Move the ink cartridge cradle gently to the left. Over to the right at it's usual resting place you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a microfibre cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now. But it's worth checking for any paper caught near the ink pad
Posted on Apr 28, 2010
My printer has come up with a service error 5c00. What can i do to fix it?
The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30.
Mar 21, 2011 | Canon PIXMA iP90v Printer
When i turn the printer on it tells me error code 5c00
Hi andrew_webb0,
The error code 5C00 means the purge unit is broken. To fix this, you have to bring the printer to a Canon service center and need to replace it with new one.
Hope this helps.
Feb 23, 2011 | Canon PIXMA MP510 All-In-One InkJet...
5c00
Error code 5C00 means purge unit is broken. To fix this problem you have to bring the printer to the service center and need to replace it with new one. I hope this brief explanation help you. Thanks
Find more printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Error code 5C00
Error code 5C00 refers to a purge unit error. This is a service call error and requires that the printer be taken into a canon authorized service facility for diagnostic and proper repair.
May 15, 2009 | Canon I900D InkJet Photo Printer
Canon printer ix4000 service error 5C00
bagai mana caranya menanggulangi eror 5c00 Printer ix4000, mohon petunjuknya
Apr 01, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Canon ip3000 shows service error 5c00
Feb 23, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Error number 5C00 Canon Pixma4000
Purge cam sensor error [5C00] - Purge unit may need cleaning.
Here is the service manual.
http://www.timtaylor.net/tech/iP4000_Service_Manual.pdf
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 27, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Mar 27, 2008 | Canon BubbleJet i560 InkJet Printer
Error code problem
Unplug printer. Press and hold power button for about 15 seconds. 5C00 is a hardware service code. Meaning there is an EEPROM error on the printer systemboard. Which may need to be replacing by a certified techinican.
Jun 23, 2007 | Canon SELPHY DS810 InkJet Photo Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
985 people viewed this question
old marine
old marine
