Question about Gaggenau Ovens
The key light on a gaggenau eb250 went on after a power outage. i cant make it go away. any idea? ia this something i can fix myself or do i need a technicien. i have tried turning off, on, resetting fuse but key light wont go away! it thinks it is on self cleaning, but I can open the door>>
  • 11,800 Answers
The controller is stuck in a loop - there's nothing you can do to fix that, the processor has been fried by the power surge that occurred during the outage.
You will have to call a certified repairman to replace the control board, you can't replace it yourself since it's not available on the open market.
Posted on Oct 09, 2010
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 | Ovens
I have an Amana AOES3030 - we had a power outage and now the only button on the control panel that responds is "oven cancel". The clock is running and where the temperature shows when cooking...
Before doing anything else, turn off the power at the circuit breaker and leave it off for a few minutes... then turn the power back on and it should start up again and be okay...
If this does not fix it then the control board is fried...from the power surge when the power went out...
heatman101
Nov 23, 2010 | Amana AOES3030 Electric Single Oven
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
Oven pilot went out due to power outage. I don't know where the pilot oven light is. where is the pilot light to light the oven?Ge XL44
pilot over lights do not require power to stay light or should it go out in a power outage! do you have to normally light pilot with a match? if not you have a glow coil and its a electronic ignition range and power will affect it. once power is restored you should just be able to turn on over and everything would be ok.if it is a pilot light you need to remove the bottom door stick arm in to back and you'll see the pilot assembly at back if you look up! hopethis helps...
Feb 06, 2010 | GE Ovens
My Gaggenau oven shows a F-40 code with the key symbol flashing. Can this be reset in any manner?
I have the same problem and the technician came out and took the oven out. He couldn't figure out was wrong and will need to contact the manufacturer technician to help him with the diagnosis of the problem. In the meantime, he says it looks like my modem is not working and may not be responding to the commands that would normally remove the key lock after a power outage.
Sorry, can't be reset - you'll need to pay the big bucks to have a technician out to assess, make sure you tell him your model number so that he can do his homework prior to coming out, that way you're not paying alot of money that I had to for this tech to figure things out. He took one hour and charged me $120 with no fix and will have to come back anyway.
Nov 16, 2009 | Gaggenau ED 220/221 Electric Single Oven
Gaggenau EB290 built in oven - F10 code
If you really cannot find in manual, contact the manufacturer for guidance.
Aug 27, 2017 | Gaggenau EB290/291 Oven
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Sep 24, 2008 | Gaggenau EB 270/271 Electric Single Oven
Single oven door latch is broken
hi we sell gaggenau parts but we are in the uk sales@gwhitedist.co.uk
May 04, 2008 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau EB294/295 Electric Double Oven
I am a gaggenau engineer this is usually a fault with the door lock mechanism it can be manually reset eg remove oven and side panel pull back locking arm there is a also a built in test prog in oven clock that will switch door lock back to reset position but these will need to be done by an engineer as oven very heavy.
ring 08705 678910 for service and/or advise
good luck
Nov 20, 2007 | Gaggenau EB 270/271 Electric Single Oven
Ovens Logo
108 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
