Question about Dell Studio XPS 8100 PC Desktop
6 beeps with regular intervals , a short puase and it repeats.. nothing comes out on screen and com does not boot..
  • Anonymous Aug 11, 2013
    clean out the tower really good with a garden hose, hope it helps.
  • 186 Answers
As stated above, you can try removing the Memory and re-seating the Memory cards.
However, 6 Beeps indicates an issue with the Video Card. If your computer is configured with a Video Card, try removing and re-seating it by following the instructions provided in the Manual. You can access the Service Manual for Studio XPS 8100 from the link below:
http://support.dell.com/support/edocs/systems/studio8100/en/index.htm
If the issue is not resolved even with re-seating the Video card, you need to check with the Warranty of the computer with Dell and get if it is under warranty, get a replacement Graphic Card.
All the Best.
Posted on Mar 23, 2011
    Scholar:
  • 103 Answers
Hello!
Try removing your RAM and insert it again, maybe your RAM was not properly inserted. And also if you remove the RAM, try to check also the other hardware and connectors (like video, hdd and etc.).
Hope I was able to help.
Posted on Oct 09, 2010
I have a P5K Deluxe asus mother board error beeps no visuals
Two beeps is usually the video card.
Do you have a spare video card to change out?
This is why people keep obsolete PCI video cards for just such tests.
Dec 05, 2015 | ASUS P5k Deluxe Socket 775 Motherboard
Tip
Beep Codes (Different BIOS) " What they mean "
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
IBM POST Diagnostic Code Descriptions
Code Description
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Colour/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Colour/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
on Dec 30, 2009 | Computers & Internet
How to boot dell inspiron one 2020 when it only beeps
the number of beeps will tell you what the problem is the beeps are an error code here are the code list for your computer
Beep Code Description No Beeps No Power, Loose Card, or Short. 1 Short Beep Normal POST, computer is ok. 2 Short Beep POST error, review screen for error code. Continuous Beep No Power, Loose Card, or Short. Repeating Short Beep No Power, Loose Card, or Short. One Long and one Short Beep Motherboard issue. One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. One Long and Three Short Beeps. Video (EGA) Display Circuitry. Three Long Beeps Keyboard or Keyboard card error. One Beep, Blank or Incorrect Display Video Display Circuitry.
May 25, 2014 | Dell Inspiron One 2020 All-in-One Desktop
Dell inspiron laptop N5040 3 beeps interval 3 beeps black screen
Explain the intervals at which it beeps, either 2 short beeps and a prolonged beep. does the hard disk LED blink? if it does its display inverter problem. if no blink on hdd LED its either RAM or cpu failure.
Oct 04, 2013 | Dell Inspiron Computers & Internet
One long beep which repeats at regular intervals. no post.
ussualy that means a problum with RAM ...... you can take the ram and clean it and replace.. if nothing happen it maybe the ram is damaged...so change the ram..........
or maybe a problum of a card u have installed...... like graphics card...
if u need more help email me :- aliumarahmed@hotmail,com
umex_umar@yahoo.com
umex_umar@hotmail.com
Jun 04, 2011 | Biostar GF7025-M2 GeForce 7025 Socket AM2...
When I try to boot my EVGA P55V micro mother board all it just goes beep beep beep, repeatedly I'm using a EVGA e-GeoForce 9600 GT card nothing apears on my screen it doesnt even look like its booting, the...
that beep (1 long and 2 short) indicated your ram has problem, from your suggestion i can know that your ram was died, change your ram with new one it will solve your problem
Feb 25, 2011 | Evga P55V 120LFE651TR LGA 1156 Intel P55...
I m using asus p5qc motherboard... currently i m having p\booting problem. i m getting 1long 3short beep... then a short beep after a small interval. and i m not able to start my computer....
1 long with 2 short beeps means Either video adapter is bad or is not seated properly.
Also, check to ensure the monitor cable is connected properly.
Open the link below for Award bios beep;
http://www.bioscentral.com/beepcodes/awardbeep.htm
Cheers'
Mike
Aug 10, 2010 | Computers & Internet
Beep then black screen
there two kinds of beep a long beeping sound and a short with interval beeping sound, if you hear a long beeping sound, it means that you a bad or broken memory module, if the beeping sound is short and with interval the problem is the vga card, if you any of this two and you want to troubleshoot it but you are not certain on what to do have a comp tech check your system to avoid any more damage to your unit
Nov 25, 2009 | HP Pavilion dv6000z Notebook
Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 25, 2009 | Toshiba Satellite X200-AA3 Notebook
Packard Bell error signals
here is a list of packard bell beep codes with meanings
http://www.uktsupport.co.uk/pb/mb/phnxcode.htm
Hope it helps you
Nov 13, 2007 | Packard Bell Easy One Silver 2101 Notebook
Dell Studio XPS 8100 PC Desktop Logo
2,225 people viewed this question
Alun Cox
