Question about Iomega ScreenPlay
I have accidentally formatted the default partitions
    Scholar:
  • 74 Answers
ScreenPlay Director Partitions
There are five partitions on the ScreenPlay Director's hard disk. Three partitions are grayed out and will list as "Healthy-Unknown" in Windows Device Manager. These partitions contain the ScreenPlay TV interface and system settings and are not available to store media files.
The two active partitions both appear as "Untitled". The larger partition is formatted with an NTFS file system. Use this partition to store your media files when you connect to the ScreenPlay Director from a networked computer or transfer files via direct USB connection.
The smaller partition is formatted FAT32 and is used only when updating the ScreenPlay Director firmware. Do not place your media files on this partition! If you accidentally store media files on the FAT32 partition, you can use a computer to move them to the larger NTFS-formatted partition. You will not be able to see media files on the FAT32-formatted partition when using the ScreenPlay TV interface.
Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
*******************************************CAUTION!*********************************************************
Do not change (format or delete) the partitioning on the ScreenPlay Director hard disk as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition (the largest partition) can be viewed or played on a TV. The ONLY partition that can be formatted is the data partition (the largest partition).
Conclusion: If you have deleted or formatted any of the first 4 partitions on the unit that is not the data partition. You now own a BRICKED ScreenPlay which HAS to be replaced. No if ands or buts about it. YOUR DEVICE IS DEAD.
Posted on Dec 22, 2010
  • abc7275 Jul 15, 2011
    If you accidentally formatted the whole Screenplay Pro, don't worry. Install the firmware once again from IOMEGA website and that will bring back your multimedia drive back to life.
  • robertdun661 Jul 25, 2011
    Do a quick format of the drive and reinstall the firmware and this will set everything up again. Check out this link for Omega support.http://www.iomegasupportforums.com/phpbb...
"write protected" unable to format
1. Open Start -> Run...
2. type diskmgmt.msc and press enter
3. right click on the partition you want to format (where the leter and size is)
4. select 'Delete Partition...' and confirm
5. right mose button in the same place and select 'Create partition'
6. select primary partition
6. select size, file format, disk letter, label etc should be all right if you leave defaults.
7. click ok
Dec 19, 2012 | Electronics - Others
I have accidentally formatted my partition drive f
Deleting or formatting won't make the data in computer hard drive erased permanently.
Those deleted data is still stored on the computer hard drive , it's just invisible or inaccessible. Only the FAT or NFTS table is erased (the information about where those data were saved), but the real data are still intact there in sectors of the hard drive.
So as long as those data are not overwritten by new data, it's highly possible to recover them. And the MOST Effective way is to rely on some format recovery programs.
Try asoftech data recovery program, which can recover data after deeply scanning your computer hard drive to look for lost data you accidentally deleted or formatted. download the software from link below
Format Recovery Software
You may refer to this tutorial for detail step by step info
how to recover files after reformat
Jul 27, 2012 | HP Computers & Internet
How can i recover my files when i accidentally formatted my drive d twice
The only chance you have is to find a free "undeleete" program and try to recover as much as possible.
Afterformatting a harddrive and later installationof Windows you cant expect to recover that much as - If the position where the file wasstored is owerwritten by windows files - recovery is not possible. If I were you - forget it - bu as mentioned there is a chance to recover some of the files. Search via google for Undeleete program (free) - or by a proper program.
Regards
Feb 17, 2012 | Intel Computers & Internet
I need to know how to partition newly purchased item into 3 or 4 partitions. A step by step guide is needed. Thank you.
IN windows OS
go to control panel from the start menu
Go to System and Maintenance
then click on Administrative Tools
then double-clicking Computer Management on navigation pane you will see storage under that choose disk management
In the right hand pane you will see each physical disk within your computer on a separate row, and each disk is displayed with it broken up into its partitions. (In the example shown there is one physical disk which is partitioned into two)
After confirming which partition you wish to remove, right click on it, and select 'Delete Partition' or 'Delete Logical Drive'. Click 'Yes' when prompted. make sure u choose the right one. these actions are not undoable. u may loose your all data.
now Right-click on the unallocated region created on your hard disk, and then clickNew Simple Volume.
you will be creating primary partition. you will get New Simple Volume Wizard, click Next.
write the size of the volume you want to create in megabytes (MB) or accept the maximum default size, and then click Next. in your case write 330,000 for 330gb partition.
Choose the default drive letter or a different drive letter to identify the partition, and then click next.
you will get format partition dialogue box.
if you don't want to format the volume right now, click Do not format this volume, and then click Next.
To format the volume with the default settings, click Next.
ideally choose NTFS and quick partition
choose finish.
create more partitions by right clicking on empty space and choosing new partition and repeating above steps.
Jul 14, 2011 | Western Digital Wd Elements Se 1tb...
Recover partition format
Did you want to recover formatted partitiom or recover the format (or called file sytem,such as NTFS and FAT32) of partition?
You can recover formatted partition with partition recovery program.I have succeed with Tenorshare data recovery.It can recover partition after deeply scanning your hard drive to look for lost data you accidentally formatted.You can get it here:http://www.any-data-recovery.com
If you want to recover the file system of partition,you can copy your data into a portable device and then transfer the file system of partition.
May 30, 2011 | Computers & Internet
I formatted the screenplay director hd drive and just have a screen saying :sleeping waiting for usb keys:
************************************CAUTION!************************************************ Do not change (format or delete) the partitioning on the ScreenPlay Director hard disk as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition (the largest partition) can be viewed or played on a TV. The ONLY partition that can be formatted is the data partition (the largest partition).
Dec 19, 2010 | Iomega ScreenPlay
I deleted some of the partitions and now the
ScreenPlay Director Partitions There are five partitions on the ScreenPlay Director's hard disk. Three partitions are grayed out and will list as "Healthy-Unknown" in Windows Device Manager. These partitions contain the ScreenPlay TV interface and system settings and are not available to store media files. The two active partitions both appear as "Untitled". The larger partition is formatted with an NTFS file system. Use this partition to store your media files when you connect to the ScreenPlay Director from a networked computer or transfer files via direct USB connection. The smaller partition is formatted FAT32 and is used only when updating the ScreenPlay Director firmware. Do not place your media files on this partition! If you accidentally store media files on the FAT32 partition, you can use a computer to move them to the larger NTFS-formatted partition. You will not be able to see media files on the FAT32-formatted partition when using the ScreenPlay TV interface. Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
*******************************************CAUTION!********************************************************* Do not change (format or delete) the partitioning on the ScreenPlay Director hard disk as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition (the largest partition) can be viewed or played on a TV. The ONLY partition that can be formatted is the data partition (the largest partition).
May 06, 2010 | Iomega ScreenPlay
Reset acer aspire one
it depends what you mean by resetting ..if you only want to reset the bios settings just go to bios by pressing f2 on start and after that choose from the menu the optimal factory defaults and save changes by pressing the F10..
this will reset the bios to default s..
If you are talking about cleaning the Hdd you need an installation CD bootable and you need to install it clean and format the hdd ...or at least the C partition cause the others you can format from windows by right click on the partition and choose format ..if it do not contain any sensitive windows or back-up data it wil;l format like a charm ...but for the C partition where the windows is present ..you have to reinstall and format during it ..
the best way is to save all data in the other partition..(D:drive) and install the windows..in C with formating it during ...than move the stuf you really need and saved in D ..into teh C partition and format the D as well..
good luck ..and do not forget to rate ..
May 01, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have bought a IOmega Screenplay Pro 1 TB. I was able to see some partition in the HD. Accidentally all these partition were removed. So i need to create those partitions and the size details of each...
Feb 22, 2010 | Iomega ScreenPlay
No matter what type of disc I insert, including store bought movies...player says ''does not recognize disc''
Mar 15, 2009 | Televison & Video
Iomega ScreenPlay Logo
1,917 people viewed this question
Top Iomega Televison & Video Experts
Martin Murray
Chris Larocque
Are you an Iomega Televison and Video Expert? Answer questions, earn points and help others
