Question about Garden
My wipper snipper is blowing smoke. Is this normal?
2 Suggested Answers
  • 57 Answers
SOURCE: I Have a stihl fs
Even touching carb jets is the very last resort, if u absolutely have too, turn them closed, b mindful do NOT over turn. Turn jet 1/4 turn and if needed 2nd 1/4 turn. no more than 1/2 turn.
Posted on Sep 04, 2011
Manual Ryobi model RCT3160E wipper snipper
makers website. and download
Oct 21, 2014 | Garden
Refrigerator overflows from evaporator pan
you have a blocked drain from the rear of your refriderator to the motor drip tray
the heat from the motor evapourates the water,
get some wipper snipper cord and push though the rear drain located inside
the refridgerator behind the plastic captulator and it will open the bockage
Dec 27, 2011 | Refrigerators
My wipper snipper has no spark, Ihave bridged out the switch to make sure its not the switch, new spark plug ,correct gap .
The switch is a kill switch that grounds out the spark, at least that is how mine is. So assuming you have it correct, and new plug, that leaves the ignition coil. Only component left.
Sep 18, 2011 | Homelite Mighty Lite Lawn Trimmer
I Have a stihl fs 38 wipper snipper. I am having trouble setting the carb jets. Can you help me?
Sep 02, 2011 | Garden
My stil wipper snipper starts and runs but only on low revs.it will not rev up
Most Stihl's are the same...Sounds like you need to adjust your mixture screws on the carby. you will need a small flat blade screwdriver (usually these are supplied with the wipper snipper from new and they have a little arrow on the top), H is for the High speed mixture screw, L is for the Low speed mixture screw. Turn the screws clockwise in until they seat (do NOT tighten!!) then turn them anti-clockwise the recommended amounts of turn on the cover around the holes. Careful not to lean the mixture out too much, but if it is the newer type they have a restictor on the High Speed that stops it at 3/4 of a turn. start it up and hopefully it will fix your problem, if not you will have to take it to a professional. Further info majority of STIHL high and low mixture setting are fine tuned via the respective rev settings , you'll have find out the particular setting from your STIHL dealer(sorry)
Nov 21, 2010 | Garden
There are three adjustments to the carbureter of the stihl wipper snipper model F585AV. One being the idle adjustment. one of the other two is the mixture adjustment. Question is, which is the mixture...
Low idle speed is one and high speed screw is the other. The idle screw is usually the one located closest to the throttle plate (closer to engine)
Feb 08, 2010 | Home
How to fix my Ryobi Wipper Snipper - Model# RLT30CD? Hi, I having been using the bump feed and all of sudden its not bump feeding. What should i do about fixing this up? Cheers Clint Baird
You may have dirt in the spool, keeping the line from feeding. Or, the string is slightly tangled on the spool, not allowing it to feed properly.
Jim
Nov 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
257 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
