Cannot re-program zenith TV
I keep getting heat run.I go to menu to memorize cable channels,when it goes threw all channels it goes back to heat run.
    Sergeant:
  • 259 Answers
First get into the service menu. Press on remote menu button until menu display goes away, then quickly press on keypad 9-8-7-6 then enter. Turn off factory mode in service menu, this should restore normal operation.
Posted on May 30, 2008
WHEN I PLUG INTO ANTENNAE--I GET " NO SIGNAL"---BUT I KNOW THAT THERE IS A SIGNAL BECAUSE I GET A PERFECT PICTURE ON MY SONY COLOR TV? HOW CAN I GET THE OLEVIA TO RECOGNIZE THE ANTENNAE SIGNAL?
You'll need to use the Olevia remote and press the MENU or SETTINGS button. The choose the SETUP or MEMORIZE CHANNELS option. MEMORIZE CHANNELS may be in an ANTENNA screen.
When you memorize channels you'll need to set the option for Antenna or Cable TV then have it memorize channels.
The television will run through each channel looking for signal and memorize those it finds. Sometimes it finds a very weak signal and you'll need to manually remove some.
Oct 04, 2015 | Sony Televison & Video
Cannot get picture or sound but can get menu screen wont select or memorize channels on cable
this TV will not tune modern cable signals. You must use a set-top box with a TV that is this old.
Feb 14, 2015 | Mitsubishi VS-8087 80" Rear Projection...
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
Hello
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
Jun 17, 2011 | Zenith H27E35DT 27" TV
I have a Zenith B25A242 TV. Can't get cable channels
Select cable, then with your remote, go to menu and perform channel scan.
Oct 31, 2009 | Televison & Video
Not all channels memorized during setup
YOU WILL HAVE TO PUT IT IN THE CABLE MODE BEFORE AUTOPROGRAMMING. IT IS IN THE MENU RIGHT BEFORE AUTO PROGRAM
Aug 17, 2009 | Toshiba 23HLV87 23 in. LCD Television
Diagram
ok i am typeing this right out of the book/
operating your tv: Once you have connected your tv to an anntenna or cable system,plugged the tv in, and put batteries in the remote, you are ready to use the tv. the first thing you should do is program your tv so it memorizes all of available analog& didgital channels.PROGRAMING YOUR TVS CHANNEL MEMORY: your tvs memory determines the channels thet are available using the "up ch down" buttons. if a channel is not in memory . you can tune to it with the numbeer buttons, but not with the up and down buttons . follow these steps to program your tvs memory:
1) Preset
press the MENU button twice to enter preset menu
To memorize all available analog and didgital channels
press the ch down button to highlight FULL SCAN then press VOL.+ to begin channel scaning, the channel scanning starting with analog channels then to didgital channels. after your tv finishes memorizing the channels, it will return to normal tv viewing. I hope that this fixes your problem thats just the main section on the programing part so if you need further info just ask!
May 21, 2008 | Disney DTD1363-CAR 13" TV/DVD
Zenith tv model #A32B41W
You probably need to get into the Menu > Tuner Setup and set it for "Cable" instead of "Off Air".
Hope that helps...
Geno
Mar 22, 2008 | Zenith B32A24Z 32" TV
Zenith tv
well 2 things come to mind, 1st go into menu and run channel scan, see if that brings them back
2nd if you see a black square on the screen of these channels turn off the closed caption, again in the menu
and if all else fails hook up cable or sat box from the video out to the video in on the tv, set the tv to video input viva remote or going to channel 00
hope this is of some help
Feb 06, 2008 | Zenith B27A11Z 27" TV
Televison & Video Logo
317 people viewed this question
Top Televison & Video Experts
Electro Med Services...
