The volume on my tv goes very loud and then shuts off and when i turn it back on it keeps shutting off .so i think its the power supply board but im not exactly sure .if it is the power supply board how much is tha part?
  • 998 Answers
Its in the power supply board just check the capacitor
Posted on Oct 09, 2010
Why my LG model VS81099 keep shutting off
Ive had the same thing happen. Its mre than likley the power supply board. I put the model and brand name in electronics on ebay and typed in power supply board. Cost me $25. Its pretty easy to get to and its usually right in the back of the TV if you take the cover off in the back. Im not sure if your a tinkerer or not but its cheaper than a new TV.
Hope this helps
Mar 05, 2015 | LG Cell Phones
WHY TV KEEPS SHUTTING DOWN AFTER ABOUT TWO SECONDS AFTER YOU TURN POWER ON WITH NOTHING ON SCREEN
If the light just goes off then look at the ballast . If the whole set goes off then look at the power supply board.
Jan 24, 2014 | Philips 50P8341 50" Rear Projection...
TV will not power up
These flat panel Tv's, all of them, sometimes have cheap Capacitors in the power supply section. They'll keep tv off and tripping relay circuits. It's not a fault in the power supply ic's, it's a fault in the main Capacitors. The IC thinks there is a leak, so it shuts down tv. It monitors voltages through comparators, and compares them to reference voltages. So check main power Capacitors and replace as needed. A lot of Chinese made Capacitors are cheap. In the big sets, they break down a lot.
Jan 15, 2014 | Zenith Z50P3 50 in. Plasma TV
19" Lcd keeps shutting off,
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, if otherwise, It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
I hope this will help in solving the problem.....
May 31, 2011 | Televison & Video
Loud Pop now it wont turn on.
the tv power supply might have failed. there are also two power boards ,x and y. this is an involved repair. better to have a repair man check it out
Jul 09, 2009 | V, Inc. Vizio P50HD Plasma Television
Sony lcd projection tv kf50xbr800 shuts down and
Hey there, from what you are telling me I think the problem is coming from your Power Supply board it sounds like it could be two things
one: the board might have gone bad and its not sending the corresponding voltage to your components and that is why it keeps turning off
example: works ok for a while then gets weak truns off and then gathers enough turn back on
two: the power supply could be over heating and it has a sencor when it gets to hot to turn off this is very rear though
please rate this solution !!!
Jun 19, 2009 | Sony Grand WEGA KF50XBR800 50" Rear...
Tv shuts off
remove all the external connections connected to the tv.then un plug the tv wire from the power outlet.then after some time just plug only the tv wire back in the power outlet.do not connect the other devices and check if the tv is working as normal or not.if it does not works then
its the problem in the power supply board of your tv.
check for the fuse on the power supply board.
for any blown capacitors or ics.on the powersupply board.
also check for any loose soldering joints on the power supply board.
calling a tech is much advisable.if do not have proper technical knowledge.
it will not be too costly to get it repaired.
it is worth getting it repaired.as this is a common fault faced by many customers.
thanks.
May 28, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
RCA Wireless headphone triggers off after 35 seconds of operation
ya the volume of your source is your issue.
if it is too low, the unit cuts out after 45 seconds or so...
crank up the volume and turn it down on your headset
Mar 16, 2008 | RCA WHP140 Consumer Headphones
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
