Question about Samsung Televison & Video
Ghosting image on samsung led tv in 3d mode - Samsung Televison & Video
    Problem Solver:
  • 18 Answers
Well i think i have got something for you...try the link samsung lcd tv ghosting
Posted on Jan 10, 2011
My tv is showing a double image like a ghost image just slightly below the normal image.. is my tv bust or is there a way to fix it? i've alreADY tried resetting and factory reset
There are many reasons for this fault. If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), or "Double image" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 09, 2016 | Bush 42" LCD TV 1920x1080, 50 Hz, Freeview...
How can I off the 3d effect in my Samsung led UN40D5500
When I looked at the specifications for the UN40D5500, that TV doesn't have a 3D video option. It does allow for 3D audio on the digital audio signal. The UN40D5550 has 3D video. To toggle through the 3D settings, press Menu on the remote (in the center of the row above the arrow toggles) and use the down arrow to go to the Picture sub-menu. Press Enter then with the arrows go to 3D and press Enter. Under 3D Mode, you can toggle with the left and right arrows through Off, 3D, 2D upconverted to 3D, side by side images or two images stacked one over the other. Press Enter to save the setting. Press Menu several times to exit the menu system.
If you do have the UN40D5500 and are trying to disable the 3D audio, press Menu and go to the Audio sub-menu. Then look under the digital audio options (SPDIF).
For other manuals for Samsung devices, go to http://www.samsung.com/us/support/downloads .
I hope this helps.
Oct 21, 2013 | Samsung "UN40D5500 40"" LED TV "
Hi! I am experiencing the following three
Hi Rafael,
First of all thank you for posting your question here at Fixya.
Please confirm if the brand and model number above is correct.
Blinking of the the LED (yellow and blue) at the front panel indicating that the lamp door cover is not seated properly. This cover will engaged to a micro switch giving the signal to the processor, once it is in open position, the unit will not power up and will experienced that kind of blinking error code. Go back to the lamp door cover and ensure that it is properly seat-in.
3D, 2D, red/green/blue ghost on the picture and letters means that the convergence circuitry gone bad. Symptoms is not connected to the light engine. The faulty parts is the convergence chips(IC). This chips are mounted on the large aluminum heat sink and starts with STKXXXX-XX (X means number). The most common STK chips used on Projection TV's is the STK392-110. You have to replaced them both on the board to resolve the issue(red ghosting). It is necessary also to check the resistance value of the resistors around its circuitry using the multimeter. For more info how to repair a convergence problem, watch the video below.
Jdvillanueva
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
Samsung 40" LED TV Display
Not familiar with this particular model of samsung LED TV, but ghosting and shadowing are usually an accepted manufacturer's defect.
If you're still under warranty or within 30 days of purchase, contact the company that sold you the TV or Samsung warranty department.
If you're out of warranty and you don't wish to deal with this, contact a TV repair shop. They will most likely tell you that it's not worth repairing and recommend you purchase a new TV.
Mar 11, 2011 | Samsung Televison & Video
Color red is warping or ghosting
You need to have the convergence chips replaced.
It liiks like 3D?
Thanks for using FIXYA
Oct 26, 2009 | Televison & Video
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
852 people viewed this question
Jerry Greenberg
Jerry Greenberg
