Question about Car Audio & Video
How to push the rear brake pusher back so i can fit the new brakes
    Sergeant:
  • 286 Answers
Make and model would help ! But the rule of thumb is that they (break calipers) rotate on a worm type mechanism back into the start position , a large pipe wrench usually does the trick !
Good Luck
Posted on Oct 09, 2010
How do you replace the rear brake caliper on a 2006 hd sportster
Start with a suitable container placed under the rear caliper brake line banjo fitting to catch any brake fluid that may leak out. NEVER reuse brake fluid. Use only Dot 5 Brake Fluid in a 2006 XLH motorcycle. NEXT remove the banjo bolt and both washers to detach the rear brake line from the brake caliper and throw away the washers, remove the pad pin plug, unscrew and remove the brake pad pin, remove the brake pads, unscrew and remove the caliper bolt pin, slide the brake caliper on the rear bolt pin away from the brake disc as far as possible. THEN with an open end wrench unscrew the mounting bracket bolt pin from the caliper mounting bracket and lift the brake brake caliper straight up and away from the brake disc and the caliper bracket.
LUBRICATING THE REAR CALIPER BOLT PINS AND BOOTS
FIRST apply about 0.4 g of G40M BRAKE GREASE inside the caliper bushing boot and the caliper pin boot and inside the boot lip to prevent sticking between the boots and the bolt pins and insert the mounting bracket bolt pin into the caliper bushing boot.
INSTALLATION
Before installing the caliper ensure that the retainer bracket is properly installed on the mounting bracket, then apply a small amount of LOCTITE 272 THREADLOCKER to the threads of the mounting bracket bolt pin, place the rear caliper assembly onto the mounting bracket and using an open end wrench thread the mounting bracket bolt pin into the caliper mounting bracket and tighten it to 87-130 in-lbs (9.8-14.7 Nm). THEN apply a small amount of LOCTITE 272 THREADLOCKER to the threads of the caliper bolt pin, slide the caliper bolt pin through the front mounting hole in the caliper, carefully insert the bolt pin shaft into the caliper pin boot in the mounting bracket and screw the bolt pin into caliper and tighten it to 15-18 ft-lbs (20.4-24.6 Nm).
NOTE that the brake caliper housing has a positive stop for banjo fitting and so when tightening the banjo bolt into the brake caliper you will need to rotate the banjo fitting clockwise until it contacts the positive stop.
THEN position a new washer onto each side of the hydraulic brake line banjo fitting, insert the banjo bolt through the washers and fitting into the caliper housing and tighten it to 20-25 ft-lbs (27.1-33.9 Nm). THEN insert the brake pads into the caliper with the friction material on the pad towards the brake disc and with the curved portion of the pad fitting into the recessed area of the caliper and the brake pad front mounting tab fitting into its slot in the caliper mounting bracket. THEN press the brake pads tightly up and against the brake pad spring and install the brake pad pin but if the pin does not easily fit in ensure that you are suing the correct brake pads and not two identical pads, that the brake pad spring is oriented correctly, that the brake pad front mounting tabs are properly seated in the slots in the mounting bracket and that the brake pads are correctly pushed tight up against the brake pad spring BEFORE the brake pad pin is installed. AND THEN tighten the brake pad pin to 131-173 in-lbs (14.8-19.6 Nm). THEN install the brake pad pin plug and tighten it to 18-25 in-lbs (2.0-2.9 Nm). THEN with the rear brake master cylinder reservoir in a level position verify the brake fluid level in the reservoir. If necessary and with the bike upright and not resting on its jiffy stand remove the rear brake master cylinder reservoir cap and add sufficient new D.O.T. 5 BRAKE FLUID to the reservoir to cause the fluid to reach the upper fluid level mark, but do not exceed this mark. THEN verify the proper operation of the master cylinder relief port because a plugged or otherwise blocked relief port could cause the brakes to drag or stick on. Do this by pressing against the rear brake caliper to push the caliper piston back into its bore and push brake fluid back through the master cylinder and into the reservoir. THEN pump the brake pedal until the caliper piston pushes the brake pads out against the brake disc and firm pressure is returned to the brake system.THEN turn ignition switch ON and pump the brake pedal to verify correct operation of the brake lamp and test ride the motorcycle at low speed to safely test the brake system. If the brakes feel at all soft or spongy, bleed the system until you get a firm, hard pedal and avoid making hard stops for the first 100 miles (160 km) to allow the new pads to become conditioned to the brake disc.
Replace brake pads at any time the brake pad friction material on either the front or rear caliper is worn to 0.04 in. (1.02 mm) or less above the backing plate and always replace both pads in a caliper as a set.
The minimum brake disc thickness is stamped on the side of the disc and it must be replaced if and when it is badly scored or worn past the minimum thickness. Maximum brake disc lateral runout and warpage is 0.008 in. (0.2 mm) when measured near the outside diameter.
May 21, 2014 | 2004 Harley Davidson XL 883 Sportster
I have a 2001 BMW 318I, E46 MODEL , HOW DO YOU FIT BRAKE PADS TO FRONT AND REAR, THANKS TREVOR.
YOU NEED A PISTON COMPRESS TOOL TO PRESS PISTON BACK IN THE BORE WITH THE BLEEDER SCREW OPEN ON THE CALIPER*.CLOSE BLEEDER SCREW JUST BEFORE THE CALIPER PISTON IS PUSHED FULLY INTO CALIPER.THIS WILL ALLOW ROOM FOR NEW BRAKE PADS AND CALIPER FIT OVER THE BRAKE ROTOR.WHEN FINISH.PUTTING BRAKE PADS ON YOU HAVE TO BLEED BRAKE SYSTEM.DONT DRIVE VECHICLE IF YOU CANT GET A GOOD FIRM BRAKES.
Oct 15, 2010 | BMW 318 Cars & Trucks
Hiya my back brakes have new pads fitted but when riding the back brakes are locking up at the slightest touch. what do i do to correct it? thanks
open rear brake resover cap ,drain some fluid out,remove brake pads,clean piston,push piston back into caliper,refit pads,pump up rear brake
Aug 22, 2010 | Yamaha WR 250 F Motorcycles
Rear pisttons on ford 500 will not push in to install rear brake pads
If you have disk brakes, and you cannot fit the new brake pads in the callipers? Loosen the brake fluid reservoir cap to allow pressure to escape. Use a large C clamp connecting it to the front and back of the piston. Turn the screw on the clamp to compress the brake piston then release the clamp. The piston will remain compressed allowing you the fit the housing over the new brake pads.
Jun 28, 2010 | 2006 Ford Five Hundred
How do i release the brake caliper pistons to be able to fit new brake pads on a renault trafic 08 van. thank you
Renault trafic brake calipers on the front can be pushed in with a G-clamp, but rear calipers need to be wound in, if you look at the piston it has notches for a winding tool!
Jun 21, 2010 | Renault R5 Cars & Trucks
Fitting rear brake pads to smart forfour
remove the rear wheels. loosen both bolts on the break caliper. push the pison back by turning it clock wise and pushing back at the same time. fit new pads and install in reverse order.
May 30, 2010 | 2008 Smart fortwo
Rear brake disc needs replacing
with car on stands use punch to remove pad retaining pins pull out pads can be tight remove 2 calliper retaining bolts move calliper away from disc remove disc retaining bolts remove disc check hand brake shoes and clean look for adjuster between shoes if it has one back it of some models just have hand brake cabel adjustment clean and fit new disc secure adjust hand brake shoes using screw driver through wheel bolt hole clean refit calliper slowley push back calliper pistons fit new pads refit retaining pins do other side pump up brake pedal check and adjust handbrake if neededcheck brake fluid level
Oct 20, 2009 | 2001 Volvo S80
Back brakes
rear brake are just pads. but you will need a piston pusher. go to your local auto store and get a universal piston pusher. should look like a four sided block with peggs sticking out. make sure the e-brake is off, remove the rear wheels, remove the calipers and replace the pads push the pistons in with the universal pusher and reinstall the caliper.
Jan 04, 2009 | 2005 Mini Cooper
Rear brakepads
assume you know that rear caliper pistons have to be wind back ? so if pistons are still proud and unable to fit new pads? disconnect the h/brake links from both calipers and ensure they are not siezed ? try wd40 to manually free em ? so they move to fully off position ? then push back pistons fit new pads then pump brakes to auto adjust ? then you will have to adjust the h/brake cable/s with h/brake off to enable to reconnect to each caliper hope this is of help to you best wishes from uk
Nov 04, 2008 | 2000 Volvo V40
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
