Question about Panasonic Lumix DMC-FZ20 Digital Camera
DMC-FZ20 won't stay on after power up
It will turn itself off in 5 seconds. Tried different batteries - same problem. I can press the shutter and get power back for about a second or two. Thanks for yoru help.
  • 27 Answers
In the camera setup menu there is an option which says power saver......increase the time frame in power saver...it will solve the problem
Posted on May 30, 2008
My DMC-FZ20 turns on but has no image in viewfinder or screen.
I never experienced anything like that with my old FZ20 but with experiences in other cameras I've found a nice, easy way of fixing things tends to be a "hard reboot" I think it's called. Turn the camera on, then remove the battery while it's still on causing the camera to shut down due to power failure. Put the battery back in and IME, all should be well.
Mar 03, 2011 | Panasonic Lumix DMC-FZ20 Digital Camera
I have a DMC-FZ20 and the tiff pictures are wrong, jpg are fine
It's all to do with SD cards greater than 1GB and the limitations of the camera firmware. For some reason the camera dumps an extra 16KB of junk 16KB into the Tiff which throws everything out.
I have a utility (drop me a line and I'll send it to you) I threw together using some 3rd party tools to fix and affected TIFF files but leave all unaffected ones alone. Just run it in the folder where you store the broken files.
Rob
Jul 05, 2010 | Panasonic Lumix DMC-FZ20 Digital Camera
Camera DMC-FZ20 fails to turn on after having a flat battery. recharged battery and used a new battery but fails to show ant life. What can I do?
Assuming that the new battery you tried was the correct type for the camera and that it was fresh/fully charged, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 12, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
Camera Frozen
Try to set your shutter speed you can do this by selecting (S) at the mode dial....
Thanks
May 25, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC FZ20
Did You try checking the sd card or turning it on and off
Nov 20, 2017 | Panasonic Lumix DMC-FZ20 Digital Camera
Lumix / Panasonic fixed lens Digital SLR problem.
try to help the lens come out by pulling it very very lightly...you should here a pop.
Mar 25, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Wont go on
Are you sure the 'New' battery is of the correct type?
what is the oriniginal Battery- Type and Voltage
What have you replaced it with?
Nov 18, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Difference between camera with image stabilization and camera without it
FZ20... wide angle = 36mm it is recomended that the average person should use a shutter speed of at least 1/36th of a second to avoid camera shake but with IS the average person can use as low as 1/5th to 1/9th of a second therefore being able to use the camera in lower light FZ20... telephoto = 432mm it is recomended that the average person should use a a shutter speed of at least 1/432 of a second to avoid camera shake but with IS the average person can use as low as 1/54th to 1/108th of a second therefore being able to use the camera in lower light
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
