Question about Pioneer AVIC-N2 Car DVD Player
Best method for connecting rear speakers yourself
How to properly connect a car 6x9 rear speaker when there are two additional wires for a two terminal speaker? I have a problem each time i try,either my left turn signal blink slow,my music stop momentarily when i signal or i get smoke from under the dashboard by the stereo.How can i tell which wire go where? By the way,these wires are spliced!
  • 1 more comment
  • JoeRock May 30, 2008
    Hey SnAKE this is a 95 GTP Grand Prix!
  • JoeRock Jun 02, 2008
    thx, you made it happen,i'm forever grateful for your help.
  • Eric Rodriguez May 11, 2010
    what kind of car is it?
The 94-95 GTP has a built in amp. Those are what the extra wires are. You have to have it re-wired or you have to use factory speakers. =) Found this out today.
Posted on Jan 26, 2009
  • 59 Answers
The other wires in the back by the speakers are NOT speaker wires. It is possible to cause a short circuit in your car and or damage your unit by hooking up the wires from stereo to non speaker wires. Smoke from the dash is never a good sign. Hopefully nothing is shorted. These are the correct wire diagrams for your car. Hook them up just as described and you will have sound in no time:) If there is no sound check all fuses. Hope this helps.......Let me know what happens.......GOOD LUCK
Left rear (+) is Brown wire. Connect that with the Green wire.
Left rear (--) is Yellow wire. Connect that with the Green/Black wire
Right rear (+) is Dark Blue wire. Connect that with the Purple wire
Right rear (--) is Light Blue wire. Connect that with the Purple/Black wire.
Posted on May 31, 2008
I have a total of ten speakers in my van and i want to know the best way to connect these speakers to my after market cd player they are all regular speakers not subs
I would pick the 4 closest ones and connect them..if your radio has rca connectors on it you can hardwire an amp for the 4 back ones..ulimately its up to how you want to hear the radio most of the time..
Mar 15, 2014 | Car Audio & Video
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
How to connect 6x9 pioneer speakers
Do you mean the Factory Speaker (Conecters) If you do they will have to be changed, To the same type of connecter that is on the speaker wires that come with the 6x9"s
Dec 05, 2012 | Pioneer Ts-a6974r Car Audio 6"x9 6x9 3-way...
Replace 2002 Range Rover Speakers with after market speakers
Yep thats ur best bet find what one is pos and neg and just wire in new connectors. Be sure u replace with same size speaker. Ie 6x9 4x8 etc. That way no holes need to be drilled other then the ones u might have to mount the specker. As well take a note of how good the wire is running through the door to the main body if u do all this work amd pull on the wires they may have already been broken innside where the door bend is if this is ur case u will habe to re run new wires from the speaker all the way through the door. The jam. And into the side kicker panel this way u know for sure ur wires are solid. Good luck.
Feb 21, 2018 | 2002 Land Rover Range Rover
How do i connect some 6x9 speakers to my head unit through the iso?
Red/Black wire or manufacturer specs' mean something buy the connector to run through the ISO maybe walmart or best buy
Jul 24, 2009 | JVC Car Audio & Video
6x9 hook up
yes conect the wire to the new speakers and it has to work
Feb 17, 2009 | Blaupunkt PCxt652 Coaxial Car Speaker
Rear speaker size in my 1993 Honda Accord
I HAVE A 93 ACCORD LX AND ACCORDING TO HONDA MINDS COME WITH 6.5" SPEAKERS FOR THE BACK AND TO GET 6X9 IN YOUR GOING TO EITHER GET THE SPACER THE COME WITH THE EX OR YOU OR GOING TO HAVE TO CUT AND THEY DONT RECOMMAND IT CAUSE YOUR TRUNK WONT STAY OPEN AND YOUR GOING TO HAVE TO BEND THE BAR UNDER THE TRUNK. HOPE YHIS WAS HELPFUL.
Dec 16, 2008 | 1993 Honda Accord
Wiring new speakers
hello melgiblett, as adding additional speakers to you current factory speakers will cause and abundance of power drain, you head unit is only designed to handle 4 speakers.. the only option would be to either splice your front or rear speakers to the new 6x9's, however you will notice a significant drop in audio volume and quality as your head unit would not be powerful enough to run all 6. with the assistance of an amplifier, you may be able to acheive all 6 speakers
May 31, 2008 | Car Audio & Video
2002 Chevy Cavalier audio wiring diagram
to the guy who is looking for the wire diagram, you can buy a wire kit for the stereo connection for about $60 from best buy or some other place like that. your car's door ding and some other things wont work with out it. hope that helps you some.
May 30, 2008 | Car Audio & Video
Peugeot 106
you could use existing speaker wire from original speakers.and or just run new wire thru plastic kick panels , thru plastic base boards theh thru plastic rear kick panel ,thru rear seat ...
Dec 08, 2007 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
Pioneer AVIC-N2 Car DVD Player Logo
435 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
