Question about Conair Dry 'N Straight Hair Dryer and Straightener
I don't know hot to use the Conair CS4J hair straightener. it was a gift and i do not have the instruction manual.
2 Suggested Answers
geokohler
  • 304 Answers
SOURCE: Straightener not working!!!!
It sounds to me like the thermal cutoff switch has blown. Straighteners have these as a safety device similar to a fuse to protect against fire in the event it gets too hot. These are not very costly to replace. Here is a link to where you can buy them and what they look like:
http://www.welco.com.cn/?gclid=CJiWv7TN2ZQCFQpzHgodl1LXQQ
Make sure you get one of the exact same cutoff point as the one designed for yours. If you put in a higher temp device it will be harder to blow but will make it dangerous as it may cause a fire if it over heats. Some shady repair men will just bypass this and it will work again fine but this is a dangerous practice as it directly puts you of danger. If you do have it repaired at a shop demand for the old thermal cutoff from your unit when you drop it off so the tech will know you know what is wrong with it and that you will check to make sure that it has really been changed. This will also not give him the chance to over charge you when he knows you know it is only a 1 dollar part and easy to change.
This device is very easy to change, If you can open your unit you could easily do this yourself. The part, as you will see on the site where you buy them, only has 2 wires one coming out of each end. You simply cut out the old 1 and replace it with the new one. You do not even have to worry which end goes where. It is like a fuse, it works the same either direction. You have to buy some wire crimp connector to connect it, you can not just solder it in due to the heat in the iron. In a pinch you could just securely twist the ends of the leads with the leads from the old cutoff if you clip the leads from the old cutoff real close to the device. This will leave you with plenty of wire to get a good twist. I always use the crimp connectors so it looks more professional.
Anyway, I hope you found this to be helpful and if you need more help feel free to ask me. I will stay with you on this until we have it fixed.
George
Posted on Jul 25, 2008
How can i fix the cord from my conair
Small Appliance Repair shop may be able to help, but probably best and more economical to just replace. If money is a factor to replace, check local thrift stores for a used one.
Sep 24, 2013 | Conair Professional Ceramic Hair...
I just got my Infinity by conair model cs32 straightener and it will not turn on or heat up. Please help.
If you just purchased it today or up to 30 days after purchase, TAKE IT BACK!!. If you start having problems from the beginning you will possibly always have them.
Sep 14, 2011 | Conair Infiniti Instant Heat Ceramic Hair...
My Conair Proshine Straightner won't warm up, although the light is on. How do I fix this? ... hot plates not heating and the light says its warming up but the hot plates won't heat up
Most heated hair appliances are protected by a thermistor that will fail if overheated. These are small, about 1/2" long, cylindrical in shape with a pointy end and a wire coming from each end. When they go bad, they do not conduct electricity (zero ohms on a meter). There is a three digit number on the side that is the shutoff temperature. You can get these at Radio Shack.
Don't bypass this safety device.
Jan 07, 2011 | Conair Professional Ceramic Hair...
Moded cs327 wont turn on any more
FIRST CHECK PLUG FUSE HAS NOT BLOWN , THEN CHECK ELECTRICAL WIRE FOR ANY BURNS OR BREAKS.
Oct 27, 2009 | Conair Infiniti Instant Heat Ceramic Hair...
My conair straightener won't heat up
that same thing is happening to me! but iv had mine for almost 2 years...exact same hair straightener, its happening to many people! i dont know if this is the problem but alot of people wrap their cords around their straighteners (i did too) and it twists the cord that conects to the hair straightener and makes it loose. i still have not found a way to solve this problem.
i would just go out and buy a new one, and if your looking for good but inexpensive i suggest vidal sassoon. they get really hot and have many settings and many different types. mine has worked greats
just remember not to wrap the cord
May 31, 2009 | Conair Professional Ceramic Hair...
My hair straighteners will not come on. I have changed the fuse and this made no difference
see that happened to me u just have to thro it away and get a new one trust me it wont work again 3 of my family memeber r butician hair ppl or whatever salonist wehatevea u wanna call them so i get free straightener hair dryers and stuff so i dont have to worry :)
Dec 20, 2008 | Conair Professional Ceramic Hair...
My hair straightener stops working when i increase the level of intensity to dry hair, what can be the problem?
Sounds like a short in the unit. It can be taken apart and make certain all of the wires are tight. Not sure what what you mean by increase intensity but if it means you oull harder it may just be too much for the unit. Try not putting so much pressure on it. Good luck.
Aug 14, 2008 | Conair Professional Ceramic Hair...
Hair Dryer cord has electrical shortage
IF you take off about a inch of wire from the plug and re-wire it [somtimes with new plug also] make sure to remember the fuse and this should do the trick.
Jun 27, 2008 | Conair Dry 'N Straight Hair Dryer and...
Conair Dry 'N Straight Hair Dryer and Straightener Logo
271 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
