Question about Ryobi Garden
I have two Ryobi Electronic rebate planer 650w and 750w and both units now will not work. I was using them on similar small jobs nothing to hard and went to use them after a 5 min rest and they failed to start very frustrating had to get the hand plane to finish the jobs. any ideas?
  • graemeandker Oct 10, 2010
    Hi there the 650w unit broke a couple of years ago so i bought the 750w just over a year ago both units broke down at different sites. Cheers Graeme.
  • 1,040 Answers
Maybe you tripped a breaker at the Breaker Box. Go to the breaker box and find the breaker that is half-way off, and flip it the rest of the way off, then back on.You can also try plugging them in a differnt socket that's on a different breaker to make sure that is your problem. If they work, then it's your breaker.
God Luck!
Jim
Posted on Oct 11, 2010
  • Jim Parker
    Jim Parker Oct 17, 2010
    Was this helpful?
    Jim
  • 10,865 Answers
Hello. If they both failed at the same time, check your electrical outlet. Maybe you have blown a fuse or popped a breaker. Joe
Posted on Oct 10, 2010
Is there a fuse or a reset button on a Ryobi 10 inch surface planer. My planer stopped working after getting too hot. Now, it won't even trn on....
check the motor for a thermal over load button
to stop it over heating take more lighter cuts as the motor is a small motor compared to what the cut can be
May 09, 2016 | Ryobi Planer. 15 Amp 13 in. Planer AP1301
Drivebelt on planer thicknesser broke need new one
I do not know the model of your planer, so I can only direct you to one of my favorite sites hoping this helps.
http://www.ereplacementparts.com/ryobi-planer-parts-c-7931_7939.html
You can right click and select open or double left click on the link. If that does not get you to the site you can select and copy the site address pasting it into your browser address bar and clicking on refresh or go. This will take you to the Ryobi planer site, and you can select your model number to find your part.
I usually cannot order just one part, since I always can find some other parts for my tools to keep them in working order.
Mar 04, 2011 | Ryobi Garden
Ryobi AP12 Thickness Planer---rubber feed rollers do not rotate
It is fixable if you are technically competent. All parts are still available online. It could be one of two problems:
1 - The rollers are driven by two gear & chain mechanisms on the height adjuster side of the unit. I did have a drive chain break once.
2 - If it isn't that than the gearbox has cracked / gear stripped under the torque load. This is also fixable, each individual gear and the gearbox housing are still available (10-09), but it requires substaintial teardown.
As you disassemble the unit just be careful once you remove the crossover height adjuster shaft - you don't want to turn one lifter by itself and have the planer higher on one side. It really is a simple teardown, just lots of parts. If you like the planer it is worth it; parts are cheap. If you are like me, you enjoy tearing stuff down to see how it's made and you hate throwing out $200 tools because only one little part broke!
Aug 06, 2009 | Tools & Hardware - Others
Ryobie ap 1301 surface planer
Here is the Ryobie support web site . You may still be able to get the manual for your service planer.
https://register.ryobitools.com/customer_session/new
Dec 22, 2008 | Ryobi Thickness Planer Blades
How to Fix Doors and Windows?
Take a look around the house or any place where you're using doors that don't swing clearly open and closed. Check to see that the door doesn't have a problem with its hinges but is actually a millimeter (or a few) too large on the top or bottom, since this is a perfect use for held power planers. Look for ragged or rough edges on wooden planks built into things like handmade bookcases. Also find imbalances on the bottom of wooden chairs and tables that cause an annoying rocking that is easily corrected by the held power planer. Use the planer to make rabbets (sometimes called rebates), or smooth and even grooves in a piece of wood that can accommodate the edge of a piece of glass, sealant or putty. Thin out pieces of wood used for do-it-yourself jobs if the wood expands from humidity and moisture. Let the wood settle in the place that it will permanently sit and then user the planer to plane the wood to the correct size. Do the work in the place that the wood will occupy if it's feasible. Take a look at wooden window frames that cause the window to stick or open and close roughly. Plane the window frame a millimeter at a time to get the window to run correctly.
Aug 27, 2008 | Bailey Stanley 12-960 - Low Angle Block...
Garden Logo
50 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
