Question about Samsung SyncMaster 173P 17" LCD Monitor
Syncmaster 173P flickering screen. on start up only goes digital not digital analog as it should
  • 13 Answers
SOURCE: monitor goes black when i turn it on
It is most likely the power saving settings on your computer, when it goes to sleep it stopps sending signal to the monitor and so when you turn the monitor back on no signal is comming from the pc. Try resetting the power saving setting in the control panel to never turn off monitor, and then see what happens when you turn the monitor back on the next morning
Posted on Sep 23, 2009
SOURCE: monitor switchs between digital and analog
I had a similar problem, the monitor was going blank once in a while (since I don't have a VGA input), so I switched the Auto Source feature to "Manual" and so far it's working fine for the past 2 days, if I run into the problem again I'll update this message.
On the side panel of your monitor, press the top button to access the menu, scroll down to the setup menu (by pressing the 3rd button down on the panel), press the 4th button down to enter the setup menu, scroll down to "Auto Source", use the 4th button to select, "Auto" & "Manual" are your choices.. press the 2nd button down to select "Manual" then the top button to exit the menu(s).
This monitor is set up to be able to do multi display with the software included. Utilizing both Digital and Analog signals. I'm not using this feature so I'm not sure how switching the Auto Source off will affect the performance of this feature.
Posted on Jan 02, 2009
SOURCE: Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Posted on Jun 09, 2009
  • 34 Answers
SOURCE: I have a Samsung Syncmaster 2053bw. Screen
First of all plug another monitor to the VC on your PC and do the same for the SamSung"I over heat"SyncMaster2 053BW. Reply!
Posted on Oct 22, 2009
  • 34 Answers
SOURCE: samsung syncmaster 730b blinking. switches from
Oct 23, 2009 - This is how it went for me..I have a Samsung SYNCMASTER2.gif 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A SYNCMASTER 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for close to 6 hours with no glitches whatsoever. So I have resnapped mine back together. I hope you can too. - I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
Posted on Oct 24, 2009
Screen just went black. Blue light is on the on button. I checked the power to ac/dc adapter and it was 14.22 V. Unit is a Samsung Syncmaster 173P.
Does the same with another PC/
It may have bad backlghts inverter board problem such as blown fuses, or worst case will be the lamp assemblies. You need to open it up.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 21, 2011 | Samsung SyncMaster 173P 17" LCD Monitor
Screen goes from digital to analog.
Unplug the analog cable from the system, and leave only the digital cable connected, and if u require to use the analog in future, then you can connect that as well
Nov 13, 2010 | Samsung SyncMaster 220WM Monitor
Samsung monitor flickers on digital but not analog
1. this may be due to cable select and or cable not being secure at connection point
2.check your instruction manual for proper setup for digital signal to the LCD monitor and the to your video source.
Mar 27, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
Screen flickering on and off.
I have the same problem with mine. I've kinda narrowed it down to it being the power supply in the monitor. was told it is about a $20 fix but we'll see
Nov 16, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
My flat screen Samsung monitor flickers on and off and goes to black for a few seconds before flickering on and off again. I tried taking out the cable connecting it to the computer and it still flickers...
Yes probably your monitor should be check by a technician. Try to see the warranty for you monitor if its still catch the warranty service for it, they may replace it. Bring it back to where you bought it.
Oct 31, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
The monitor turns on and the computer image comes on for about a second then screen goes black again. The image that does come on is perfect.
I'm having the exact problem. I just got the new monitor & I replaced my 18". When I plug it in it flickers, when it does come on it's clear & clean; but after a few minutes it goes black. I tried to switch it to Digital & Analog, but I don't know how to fix it. I know it works, it was just plugged into my brother's computer. Is something wrong with the settings on my computer? If so, how do I fix it? I have both monitors hooked up on my computer desk right now, it's a bit crowded! PLEASE HELP ME!!!
Oct 22, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Monitor goes black when i turn it on
just a big hardware problem in your monitor
Sep 23, 2009 | Samsung SyncMaster 216BW Monitor
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 173P 17" LCD Monitor Logo
56 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
