Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Electrical problem I went on a ride on my 1994 fatboy, shut it off to take a break, went to start it up and heard a "pop" sound then it wouldnt start. A friend had to push start me, and it was running rough and I lost all lights EXCEPT my parking lights (which got twice as bright)......I have a new battery installed also. Any help with this?
  • lxnitrous May 31, 2008
    Ok, thank you much! Another person too told me it might be the voltage regulator also . I was gonna check the fuses but the screws that keep the cover over them are stripped out and cant be removed w/o drilling them out......fun, fun. I appreciate your input and advice, Thanks again!
  • keithq Jun 02, 2008
    front cylinder wont run .plugs-wires were replaced to check wire, not the problem .bike ran fine
    .as i was riding, the front cylinder lost power as if a plug
    fouled.motor is fresh-compression is fine.i looked for a short and
    thought i fixed it but no luck. no fuses are not blown or blowing.motor has a fuel
    injected. It has the stock cam and
    ignition. It just won't run on the front cylinder. I WOULD BE GRATEFUL FOR ANY HELP money is tight and this is
    my mode of transportation. Thanks for any help .
Sounds like a possible voltage regulator problem.check to ensure battery terminals are tight.make sure there are no shorts.also first check for a blown fuse.that more than likely is your problem!!! ROBERT-BIG RED ONE !!!
Posted on May 30, 2008
2004 Saturn 5spd wont start cant pop clutch to start and now coolant and pwr str light flashing on dash
Try adding water absorb ant fluidd, ie heat. To fuel. May have condensed water in tank. Popped a fuse or breaker
Dec 26, 2017 | Cars & Trucks
I just went outside to crank my car to leave but when i turned the ignition over my car wouldnt start. The lights,radio and everything else is working fine except for some crazy things that popped up on my...
It sounds like the car is still in gear make sure it is set all the way to park, this will give you the same problems. If this does not help repost.
Mar 30, 2011 | 1999 Pontiac Grand Prix
The oven was on and I was baking. Heard a 'pop' then the oven went off. I flipped the stove breaker on my electrical board back on and it took the whole power to my house out. Flipped the stove breaker...
element has blown, pop is it breaking, that heating element will need replacing, failing this and elements all working water may have gotten to the electrics this would cause the pop and shut down all electric as well.
Jan 02, 2018 | Heartland 3525SS Dual Fuel (Electric and...
I gust bought a 2007 night rod special without a user manual. The bike would not restart after a short ride. I turned on the ignition switch, pulled in the clutch and heard an electrical pop from the...
Hi Agfanara804, call, take a ride or trailer your bike over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary/possible and offer professional advice and assistance concerning your issue. Good luck have a nice day.
Aug 23, 2010 | 2008 Harley Davidson VRSCDX Night Rod...
I am having electrical problems... 94 Cavalier
sounds like it might be your alternater a shop can test it to see if it is putting out any power
Aug 19, 2009 | 1994 Chevrolet Cavalier
Knocking
the knocking is probably the connecting rod that is between the piston and the crankshaft....the pop you heard was it breaking. this is major engine repair and needs to be looked at by profesionals.
May 05, 2009 | 1997 Buick Park Avenue
Hood latch
Yup mine did the same thing it needs to be oiled use a spray oil and also if it is cold were you are the hood latch cable can stick open so spray the cable inside at the latch Lockdicer will help for cold days. If your latch is hard to pull <latch handle> don't force it. It will break so if the car will start warm the car up first this will melt the ice. The sceeching is the powersteering pump check the fluid if low if it is not low then it is your pump not to hard to replace. Hope this helps
Jan 16, 2009 | 2000 Chevrolet Malibu
Tv popped and shut off
Burnt small 2KV capacitor near flyback xformer....original is
221K....I use 271K / 2KV ...Possible burnt 1K 1/2 watt resistor
and shorted zener diode ....ECG 519..................T.
Dec 08, 2007 | Zenith B27A11Z 27" TV
Lands Phones Logo
147 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
