Question about Dell Optiplex GX110 (2909T) Motherboard
Sir, I have a Dell optiplex GX110. At the motherboard there is a long brown slot in which a board of 4 expansion slots has been pluged. The first problem was that I had removed the heat sink from the processor and turned on the system, After it entered windows, it freezed and stopped working, which i guessed, was due to the overheating of the processor(Intel Genuine P3). Then I restarted with heat sink mounted on the processor, but it had been freezing countineously, sometime in the BIOS, some times a little later. But i noticed that the processor light in the fron panel left off working. I checked my processor,RAM,PSU at an other motherboard, so all these worked well. Then I pluged all of these in my own, this time the PSU turned on, also the processor fan too, but I received an amber light at the power LED, and there was no video display signals. I removed the board with 4 expansion slots from the brown slot, all the drives, replaced my PSU, replaced my RAM and processor and powered on the system. I was still receiving amber light, with the PSU and CPU fans properly working. I insert an electricity test pin at the long brown slot. I saw a little spark and the CPU fan turned off. Now when I turn the power on, the green light at the motherboard turns on but when i press the atart button, the CPU fan doesn't starts nor I receive any video signal. What is your opinion?
  • Dell Master
  • 32,281 Answers
When you inserted a test probe into the slot and you saw a spark, then you have short circuit a component on the motherboard and have done a major damage to the motherboard.
You need a new motherboard, most desktop cases have standard mounting holes, you may be able to purchase a motherboard from other manufacturer to fit in the Dell.
Posted on Oct 09, 2010
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
HOW MUCH RAM CAN GX110 CAN SUPPORT
This model can handle up to 512 MB of RAM , this is a link for the complete details of this unit.
http://www0.dealtime.com/xPF-Dell-Optiplex-GX110-GX110
Apr 28, 2010 | Dell Optiplex GX110 (2909T) Motherboard
I am trying to connect to a wireless internet network
If you have Wireless networks available, and you just need a network adapter for the system, here is a good suggestion:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833130111
The adapter connects to the system via USB, and setup is pretty simple
Sep 30, 2009 | Dell OptiPlex GX260 PC Desktop
My dell optiplex GX110 motherboard problem
I would suggest defaulting the bios, either by way of the cmos jumper, or by entering the bios at boot, selecting "load defaults" from the menu at the bottom of the screen, save and exit. If setting the defaults does not fix the onboard IDE then you have a hardware failure. They make IDE adaptors that plug into a PCI slot, that could get you back into operation, but I'm afraid if the IDE has gone on the mobo, what's next? I would be afraid something else will fail.
Maybe you'll get lucky with the defaults.
Jul 14, 2009 | Dell Optiplex GX110 (2909T) Motherboard
Want to upgrade the video card but dont know where to start. are the three expansion slots at the bottom of the board used to expand drivers like the video?
Hi there.
Seeing as the graphics on that board are integrated Intel Extreme Graphics and the board does not have PCI Express or AGP slots then you can use one of the 3 PCI expansion slots to install a video card.
The largest PCI graphics card I've seen is a 512MB card and that was not cheap as the latest video slots are PCI Express.
It will however free up essential system memory which is always a good thing.
Regards
Jun 11, 2009 | Intel D845GVSR Motherboard
Install ethernet card optiplex gx260
That slot is actuall not accessable externaly. The open bay is for the AGP slot right next to it. Directly to the left of that slot you have a riser board the provides 2 additional horzontally mounted pci slots. You'll have to use one of these.
May 11, 2009 | Dell Ethernet Card Network Adapter
Upgrading Graphics accelerator
Not every computer is the same, but many times you can disable your integrated graphics by going into the BIOS setup and disabling the onboard graphics. This is not necessary, even if you plan to upgrade.
http://support.dell.com/support/edocs/systems/opgx110/ens/ug/specs.htm#expansion_bus
when i read the system specs it says it only has PCI expansion slots. I regret to inform you your computer is very limited in its ability to expand, basically you will not be able to upgrade to render graphics for more 3d applications especially newer games. you need at least one AGP port or PCI Express. However if you absolutely want the best available for PCI you can purchase a RADEON 9000 PCI edition. It can handle most older 3d games or apps and it will work on your computer. All you have to do is plug it in to any PCI slot and install the software that come with the device, and voila.
http://www.amazon.com/ATI-Radeon-9000-64MB-Video/dp/B001339YIC
For newer 3d apps and games you will have to purchase a new system.
Dec 30, 2008 | Dell OptiPlex GX110 PC Desktop
Cannot find primary drive 0 (C:)
Make sure the boot sequence is set to look for the hard drive first and also make sure that the hard drive is set to cable select and is the only hard drive on the IDE cable and is plugged into IDE slot 0 on the motherboard.
Nov 15, 2007 | Dell OptiPlex GX110 PC Desktop
Installing a network card
Make sure the slots line up perfectly. It should be pushed firmly and evenly into the slot. Make sure that the metal bracket is not in the way or hitting anything else.
Oct 26, 2007 | Dell OptiPlex GX110 PC Desktop
Type of RAM for Dell Optiplex gx110
the easiest thing to do is go to crucial.com and click scan my computer, and it will tell you which type of ram your motherboard takes http://www.crucial.com/
Jun 22, 2007 | Dell Optiplex GX110 (2909T) Motherboard
Dell Optiplex GX110 (2909T) Motherboard Logo
160 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
