Question about Toshiba Satellite M45-S2692 Notebook
I think my Toshiba m45 s2692 is overheating.
My laptop out of no wear will shut down. I think it is overheating. Any suggestions. I have the laptop for 3 going 4 yrs I think.
This is an easy fixthere is dust clogging the heat sync. left side bottom there is a odd sized panel with a single screw holding it you cand access the heat sync there remove the screws holding it and remove and clean the fins and serrounding areas where you see dust buildup. reverse install your good to go no more shutting down sue to over heating.
Posted on Mar 19, 2009
    Problem Solver:
  • 45 Answers
Can you acess the heatsink?
If you can try taking out the dust. Or use a air duster and blow out all the air.
Posted on May 30, 2008
OMG spent days on this one finally read the right answer well the laptops been on for more than 10 mins which is a good sign
change the bios setting for the cpu to low (thats it) all is good i think
Posted on Jun 24, 2012
Gostaria da ajuda dos amigos!
Me refiro ao drivers do toshiba satellite m45 s2692
Posted on Oct 16, 2008
Volume control knob broken on front of Toshiba Satellite M45 S2692 laptop. no sound now at all from laptop???
This cannot be fixed any way other than repairing the knob or short circuiting the contacts where the potentiometer used to be (not recommended) as your volume will be on full all the time although you could use windows to software turn it down. because if you are going to do that, it wouldnt be much more work to replace the knob.
Apr 21, 2011 | Toshiba Satellite M45-S2692 Notebook
I have a Toshiba Satellite M45-S2692 and it works great but the battery will no longer hold a charge. I have heard about recalibrating batteries but nothing found on the Toshiba website or this one...
Time for a new battery. Sorry for the bad news! var fctb_tool=null; function FCTB_Init_1fd6691889934fc99c85cdc6ce7f1bd6(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_cce29e77a6fe4e06b7d7db85efe63209(t) { fctb_tool=t; start(fctb_tool); }
Dec 22, 2010 | Toshiba Satellite M45-S2692 Notebook
Need sound card driver compatible with vista
http://drivers.softpedia.com/ u can download driver from this link
Jun 24, 2009 | Toshiba Satellite M45-S2692 Notebook
Ok annoying problem toshiba laptop m45-s2692
You need to get/purchase the connector from Toshiba.
Jun 21, 2009 | Toshiba Satellite M45-S2692 Notebook
Wont bot
Try starting in the Safe Mode; you can access a short menu using either F5 or F8 during the first few seconds after power on. That will load very little of Windows and you can troubleshoot from there.
You might first try booting again and recording the last lines of text as this may also be a clue to the problem.
Oct 29, 2008 | Toshiba Satellite M45-S2692 Notebook
Open Questions:
BSOD when trying to install Win XP, or boot Win XP from hard drive BSOD screen is as follows: A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: The BIOS in this system is not fully ACPI compliant. Please contact your system vendor or visit http://www.hardware-update.com for an updated BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable the ACPI and allow you to continue your installation. Technical information: *** STOP: 0x000000A5 (0x00000011, 0x00000006, 0x00000000, 0x00000000) Every BSOD I received was this exact code. I ran a RAM test with memtest86+, it showed 0 errors. I tried reinstalling BIOS v 1.1 (supplied by Toshiba) and the first time it did let me boot into the XP Home installed on the system, after which it worked fine. While in xp, I checked device manager to see if the system was ACPI, and it was. I've also tried BIOS v 1.2, the last one supplied by Toshiba, to no avail. I did try pressing F7 during one of the installation attempts, and it hung at "setup is starting windows", I tried pressing F5 during an attempt, and there was only one option besides "other", the typical i486, which I selected, after which it hung at "setup is starting windows". I've flashed BIOS with v 1.2 a few times now, with same BSOD during both xp install attempts and boot attempts. What baffles me is the errors did not show up until I tried to install xp for the first time. Before that the computer booted every time. I've never heard of xp effecting BIOS during install. I have been to the microsoft support page for this BSOD. There are two articles on this specific code that I found, one for a "wake from hibernation" error, and the other for an xp installation error, seems as though the latter applies here. URL below. http://support.microsoft.com/kb/314830 I'm fixing this for a friend. I fix computers all the time. This one is getting up there with DELL's laptops. The screen is broken, so I'm using an external monitor. He doesn't want the monitor fixed, so I'm only doing a fresh install + Backup for him. Thank god I already backed up the data. Thank you in advance for your time. (I just got the error again. Gonna try windows 7.)
Jan 21, 2013 | Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite M45-S2692 Notebook Logo
322 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
