Question about Electrolux Washing Machines
EWT 1132 top loading washing machine bought in 2006 in Finland When machine is filled and plugged in ready to be started, I need to hold down the "start" button for 10 seconds before it appears to "understand" that I want it to work. Is this a sign that it needs to be looked at/serviced? Thanks! Cory in Finland
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
  • 351 Answers
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
timer or timer module fault
Posted on Mar 02, 2008
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
  • 101 Answers
SOURCE: How can I fix my Hoover Washing Machine, model H130E?
which light?
Posted on Apr 23, 2008
freetek
  • 5568 Answers
SOURCE: Washing machine keep filling in water non-stop
There is a mixing valve that is normally where you attach the feed hoses.
In US domestic machines, this is an inexpensive ('cause it's a piece of marginal junk) that can be had from nearly any appliance shop and is generally easy to replace once the back panel is removed.
I'm not familiar with your LG machine so the statement above may be useless.
Posted on Jun 29, 2008
My EWT 959 starts to fill then after about 20 seconds stops and does nothing. After a while it says turn on taps. Is there filters we can check and clean which may be confusing the machine?
Hi,first has some one turnd the water supply off for the washing machine,there are usally little filters that are where the water supply hosses connect to the back of the machine,hope this was some help all the best.
Mar 05, 2016 | Electrolux Washing Machines
Electrolux ewt 115
Hi Cong Tran.
To buy parts for your machine you should go the the manufacturers distributor with the full model number. (The shop where you bought the machine may be able to help you with that information) The parts shop can easily tell you cost and availability of the part.
Good Luck
Cheers
Nomess
Jan 03, 2015 | Electrolux Washing Machines
We just bought the washer and now it will stay on for 5 mins then all buttons blink and it says LF
LF stands for long fill,if it takes longer than a preset time by the machine it will go to LF,check water fill hoses for kinks,plugging that will slow down water fill time
Sep 11, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Neptune Top Load fills the water, the motor doesn't start.
If i understand correctly you are stating the breaker shut down which means the house breaker for the outlet power kicked out. You might try plugging something else into the outlet to see if it also kicks out, say a vacuum cleaner of a drill.
You need a amp clamp to test for something shorted or grounded (or ohm out windings) which requires trained service........you do not want to get a shock
Jan 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
GE PROFILE WASHER DOESN'T CYCLE TO WASH FROM FILL
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 19, 2009 | GE Profile WPRE6100G Top Load Washer
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Washer will not fill
Check your inlet hose from the wall socket, it could be clogged with something. Look also at the machine hose. First turn off the wall hose, and keep a bucket ready.
Sep 07, 2007 | Kenmore 94812 Top Load Stacked Washer /...
Washing Machines Logo
101 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
