Question about Gaggenau ED 220/221 Electric Single Oven
My steam oven shows the error code F71 what does it mean and who can I fix it
3 Suggested Answers
paulc118
  • 15 Answers
SOURCE: Error code On Miele Steam oven - oO
o O means that the unit needs to be descaled. See your owners manual for the procedure. If the unit displays O - - o, the safety lock has been activated. Again, see your owner's manual.
Posted on Feb 27, 2010
  • 414 Answers
SOURCE: we have an Gaggenau EB 290 oven and the error code
F23-relay electronics not selecting. There is either a fault with the pcb or a loss of continuity within the ribbon cable. Unfortunately, I think you are going to need an expert to look at this to confirm.
Sorry I cannot be of more assistance but some faults do require a physical check from a professional and cannot always be sorted out from a distance.
All the best.
Posted on Jul 13, 2010
F71 code on double oven
These error codes are normally make-specific.
Replace the word 'double' with the 'make' and press enter.
F71 code on double oven Google Search
Aug 07, 2017 | Ovens
F74 what does this mean
.. error code f74 Water pressure switch is staying closed.
Apr 10, 2016 | Miele DG155-1 Steam Oven Single
How I can fix the Message
Depending on the make of the oven the error code E011 can indicate a faulty temperature sensor or bad control panel when steam escapes from the oven and into the panel. In either case this issue usually requires a repair technician to fix the problem.
Dec 23, 2014 | Ovens
F8 E1 error code
anyone able to tell me what the E1 F8 error code means on a Whirlpool duet steam washer?? it keeps stopping mid cycle...
Jan 05, 2014 | Jenn-Air Ovens
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
Feb 01, 2010 | Miele DG155-1 Steam Oven Single
Onen display shows f3
The F3 error code relates to the oven temperature sensor and usually means this has failed and needs to be replaced.
It is a reasonably straightforward job, details of which you can find here; www.fixitnow.com/2003/02/appliance-tip-of-the-day-oven-temperature.htm
Jan 18, 2010 | Ovens
Gaggenau Ed 220/221 Error Code F 70
I had the same fault F70. Poured several liters boiling water no result. I decided to take the oven out the kitchen and put on the table. Be carefull, its edges are sharp. You need to disconnect water supply, first close the tap, then remove the water pipe from the oven by hand. Remove also the drain pipe from the sewage connection. You cannot detach it from the oven. Unplug power supply. Then start unscrewing the top panel. Once removed you can unscrew also the side panel left side (by looking at the oven from the front door side) and finally remove the back panel. You will need a special screw driver as the screws are star type.
I found out that there was some little water on the bottom panel of the oven. There is a safety sensor which is in contact with the bottom panel on the left side of the oven near the electronic board.
If this get wet, the faul code F70 appears.
Also some water was in the hole of the level sensor in the pump chamber next to the other sensor (white plastic box)
So dry all the water with the help of kitchen paper and finally with hair dryer.
Put back all teh parts and voila', it works again.
Feb 20, 2008 | Gaggenau ED 220/221 Electric Single Oven
Gaggenau ED 220/221 Electric Single Oven Logo
205 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
