Question about Food Mixers
Sauce maker/stirrer I have an old Salton type 8360 sauce maker. I am missing the arm for stirring. Any chance of finding this part?
I have just purchased an ice cream freezer for my mixer. It is an older model and does not have a "stir speed" delineated. What is the equivalent of stir speed on the older models? -- 1 or 2?
On models with the "STIR" speed, the RPM (Rounds Per Minute) is 60.
Set your mixer speed to "1" or "2" and do the following:
Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. In your case, the correct STIR speed is 60.
Jul 29, 2011 | KitchenAid KSM50PR Professional Series...
I am trying to find out what attachments are available for the kenmore KSM035
There are no longer attachments available for this model. See here for available parts:
http://www.searspartsdirect.com/partsdirect/part-model/Salton-Parts/Mixer-Parts/Model-KSM035/0915/0212320/50019525/00001?blt=06&prst=0&shdMod=KSM035
Would need to source from a secondary distributor or find used accessories.
Mar 09, 2011 | Kenmore KSM035 Stand Mixer
12c 150 watt missing front dial
type in the manufacturer in the search bar and sometimes you can find the history leading to the current ,anufacturer and service centers. Good Luck
Sep 21, 2009 | Sunbeam 2485 MixMaster Series Hand Mixer
The beater shaft seems jammed. I can't push it up to remove my beater.
best returned to service centre as these are very hard to get apart.
Sep 15, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Mixer won't start
I have a PDF file entitled "kitchenaid service manual" that I could send you that I got online and can't remember where. If so my email address is mass78337@mypacks.net Send me an email and I'll reply with the PDF enclosed. Otherwise try a google search of the above and you might be able to find it.
It's looks old but covers all the essentials including a wiring diagram
Apr 21, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid ksm50pob no stir speed all other speeds seem ok
I don't know if it will work for you but move the speed lever from front to back a few times as fast as you can. This will polish the contacts. This is like the old fashioned TV tuners. People used to turn them slowly and then complain when they needed serviced every 6 months. Spinning the tuner knob kept the tuners working flawlessly for years.
Jan 08, 2009 | KitchenAid KSM50PR Professional Series...
"Stir" and "2" mix function no longer operate
Yes, your Kitchenaid mixer and be repaired.
You may use the following link to find a Kitchenid certified service center locally to you:
http://caservice.kitchenaid.com/
Dec 30, 2008 | KitchenAid KSM103 Professional 5 Series...
My mixer was straining to stir bread dough. Now the motor turns on, but the arm does not rotate.
Did you hear a CRACK sound just as the mixer stopped running? If so, the plastic transmission housing may have failed & destroyed the worm gear and the front and rear bearings and possibly deformed the bearing seats as well. It happened to me. Although these machines are marketed stating that they can knead bread dough, they can't. Mine failed 5 months out of warranty, after only30 batches of Sourdough Bread. Take the top cover off of the mixer and look for the transmission housing near the front of the mixer. If there obvious cracks in it, it is your problem.
Dec 03, 2008 | KitchenAid K45SS Classic Stand Mixer
There are no low speeds. Runs medium on "stir" setting.
see the solution at http://www.fixya.com/support/t501377-speed_switch_gone_beserk
Nov 04, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Food Mixers Logo
70 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
